Author Topic: Aligning two objects with one along its X-axis  (Read 1054 times)
dpenney
« on: July 29, 2015, 04:52:25 PM »
In model space of AutoCAD Mechanical 2015, I have two objects in space that will eventually become the outline of a laser cut 3D plate. Both objects have been drawn to suit/match two other objects. Now I want to align them by moving a circular object along its X-axis to completely align with a rectangular object.
So the question I am asking is this, is there any easy/quick way to align an object (with another entity) moving along an X, Y or Z axis?
Refer to screenshot for clarification.
Any help appreciated.
Stefan
  • The most I miss IRL is the Undo button
Re: Aligning two objects with one along its X-axis
« Reply #1 on: July 29, 2015, 06:37:28 PM »
Select the circles. In the properties dialog, type 0.0 in Center X box and press enter.
Or, if you set the UCS on rectangle's plane, you will need to change Center Z instead.
dpenney
« Reply #2 on: July 29, 2015, 06:55:09 PM »
Hi Stefan,
I like it....so simple.
Cheers.
