Author Topic: noob question ... Ctrl-c for cancel  (Read 3478 times)
CatDance
« on: May 05, 2020, 04:20:54 AM »
How to make Ctrl-c = cancel command ?
I try to replace Ctrl-c = "Copyclip" to c^c^ (in the CUI) but it only do a soft cancel ie. when selected gripmodes on screen, it won't do a hard cancel by removing selected gripmode. Only pressing Esc key do a hard cancel.
I am used to pressing Ctrl-c as my fingers are nearer to Ctrl key.
Thanks.
A must-read book: Amazing story how Bill + Paul started Microsoft and history of computer revolution.
https://www.amazon.com/Hard-Drive-Making-Microsoft-Empire/dp/0887306292
Brief history of Microsoft
https://www.youtube.com/watch?v=BLaMbaVT22E
Re: noob question ... Ctrl-c for cancel
« Reply #1 on: May 05, 2020, 09:46:33 AM »
How about something like this:
  1.  (defun c:zz nil (command) (princ))
IMO redefining OOTB commands is bad practice.
wizman
« Reply #2 on: May 05, 2020, 11:02:10 AM »
If Copyclip is set to C^C^, then QAFLAGS must be set to 1 to drop the grips.
CatDance
« Reply #3 on: May 10, 2020, 03:38:33 AM »
Ok, Ron.... I will not redefine the "OOTB" commands (what is a OOTB ??  :embarrassed:)
CatDance
« Reply #4 on: May 10, 2020, 03:40:24 AM »
Ok wiz I will try this.
CatDance
« Reply #5 on: May 10, 2020, 03:46:46 AM »
Thanks, Wiz. It worked.
wizman
« Reply #6 on: May 10, 2020, 03:55:09 AM »
CatDance, please have also a research of what the qaflags do to other commands and as Ronjonp advised, consider to leave the default commands untouched.
« Reply #7 on: May 10, 2020, 12:09:01 PM »
Out Of The Box?
tombu
  • ByLayer=>Not0
« Reply #8 on: May 11, 2020, 12:06:50 AM »
While I wouldn't advise ever modifying the acadXXXXdoc.lsp version specific lisp file that comes with each version most of the functions defined there have been around for many years. and are always available. I've used ai_onoff for toggling system variables in CUI macros. It was used in installed MNU files a quarter century ago.
;;; Shortcut menu Deselect All item.
(defun ai_deselect ()
   (if (= (getvar "cmdecho") 0) ;start if
       (command "_.select" "_r" "_all" "")
       (progn ;start progn for cmdecho 1
           (setvar "cmdecho" 0)
           (setvar "cmdecho" 1)
       ) ;end progn for cmdecho 1
   ) ;end if
   (terpri)
   (prompt "Everything has been deselected")
;;; Command version of ai_deselect to be called from the CUI
;;; so it gets properly recorded by the Action Recorder
(defun c:ai_deselect ()
  (ai_deselect)
ai_deselect works no matter the situation in AutoCAD products.
Tom Beauford P.S.M.
Crank
« Reply #9 on: May 14, 2020, 08:09:06 AM »
I try to replace Ctrl-c = "Copyclip" to c^c^ (in the CUI) […]
That's one CANCEL: Try ^c^c
