Author Topic: Dimension Text - Dtext or Mtext  (Read 11191 times)
Re: Dimension Text - Dtext or Mtext
« Reply #30 on: January 20, 2006, 07:10:09 PM »
Worked for me although I added this.
(defun c:RewriteDimText (/ ss Ent tmpEnt EntData OldStr NumStr)
(if (setq ss (ssget "x" '((0 . "DIMENSION")
 (-4 . "<NOT") (1 . "") (-4 . "NOT>"))))
<snip>
That is a good add.  I don't use the "-4"s at all with ssget.  I guess I should learn that one one of these days.
« Reply #31 on: January 20, 2006, 08:32:31 PM »
Thanks Tim,
Well this is as far as I got, fighting the flu, so maybe tomorrow.
Did not know how to get the actual rotation of the dimension line.
(defun c:fixdims ()
  (setq doc (vla-get-activedocument (vlax-get-acad-object)))
  (vla-startundomark doc)
  (and (or (ssget '((0 . "DIMENSION") (-4 . "<NOT") (1 . "") (-4 . "NOT>")))
           (ssget "X" '((0 . "DIMENSION") (-4 . "<NOT") (1 . "") (-4 . "NOT>"))))
       (setq ss (vla-get-activeselectionset
       ) ;use ActiveX ss
       (setq mspace (vla-get-modelspace
       (vlax-for x ss
         (if (vl-string-search "%%2" (setq str (vla-get-textoverride x)))
            (vlax-dump-object x T)
            (if (setq newobj (vla-addtext mspace str (vla-get-textPosition x) (vla-get-textheight x)))
                (vlax-put-property newobj 'Alignment  acAlignmentMiddleCenter)
                (vla-put-textAlignmentPoint newobj (vla-get-TextPosition x))
                ;;(vla-put-Rotation newobj (vla-get-Rotation x))
                (vla-put-StyleName newobj  (vla-get-TextStyle x))
                (vla-put-Height newobj  (* (vla-get-ScaleFactor x)(vla-get-TextHeight x)))
                (vla-put-Layer newobj  (vla-get-Layer x))
                (vla-put-Color newobj  (vla-get-TextColor x))
                (vla-put-textoverride x " ")
                (vlax-release-object newobj)
              (prompt (strcat "\nERROR replacong dimtext " str))
       (vlax-release-object mspace)
  (vla-endundomark doc)
« Reply #32 on: January 20, 2006, 09:37:41 PM »
Just to throw out another idea......
Why not just change the "%%XXX" to be the actual symbol? To get MTEXT to display the character defined as 202, in the editor hold down the ALT key while typing 0202 on the numeric keypad. This works in lisp, too. Just set up a (cond) based on the value of "%%XXX" and set it to the corresponding ASCII value......it will display differently based on which font is used, just as it does now.....and there's no messing with exploding blocks and getting a TEXT object to appear exactly as the MTEXT object did.
Aw heck, here's my stab at it...note that I do not have a drawing to test this on.....so as MP would say: YMMV ;-)
(defun c:FixDimText (/ ss Ent obj txt pos code new)
  (if (setq ss (ssget "x" '((0 . "DIMENSION")(-4 . "<NOT") (1 . "") (-4 . "NOT>"))))
    (while (setq Ent (ssname ss 0))
      (setq obj (vlax-ename->vla-object ent)
    txt (vla-get-textoverride obj))
      (if (wcmatch txt "*%%###*")
  (setq pos (vl-string-search "%%" txt))
  (setq code (atoi (substr (substr txt (+ 3 pos)) 1 3)))
  (cond ((= code 202)(setq val "Ê"))
((= code 203)(setq val "Ë"))
((= code 204)(setq val "Ì"))
((= code 205)(setq val "Í"))
((= code 206)(setq val "Î"))
((= code 207)(setq val "Ï"))
((= code 208)(setq val "Ð"))
((= code 209)(setq val "Ñ"))
((= code 210)(setq val "Ò"))
((= code 211)(setq val "Ó"))
((= code 212)(setq val "Ô"))
((= code 213)(setq val "Õ"))
((= code 214)(setq val "Ö"))
((= code 215)(setq val "×"))
((= code 216)(setq val "Ø"))
  (setq new (vl-string-subst val (strcat "%%" (itoa code)) txt))
  (vla-put-textoverride obj new)
        (ssdel ent ss) ; CAB added
« Last Edit: January 20, 2006, 10:10:28 PM by CAB »
« Reply #33 on: January 20, 2006, 10:05:45 PM »
Party pooper. :-D
Just kidding Jeff, nice solution.
Here is my last attempt tonight.
The problem with the dimension angle has been approached by using dxf codes 10 & 11
But when the extension lines are not equal length this angle is incorrect.
There must be a better solution somewhere.
(defun c:fixdims (/ doc elst mspace newobj ss str)
  (defun get_angle (obj / ang)
    (setq elst (entget (vlax-vla-object->ename obj)))
    (setq ang (angle (cdr (assoc 10 elst)) (cdr (assoc 11 elst))))
      ((and (> ang (/ pi 2)) (<= ang pi))
       (setq ang (+ ang pi))
      ((and (> ang pi) (< ang (* pi 1.5)))
       (setq ang (- ang pi))
       (setq ss (vla-get-activeselectionset doc)
       ) ;use ActiveX ss
       (setq mspace (vla-get-modelspace doc))
       (vlax-for x ss
             (vlax-dump-object x t)
             (if (setq newobj (vla-addtext mspace str (vla-get-textposition x) (vla-get-textheight x)))
                 (vlax-put-property newobj 'alignment acalignmentmiddlecenter)
                 (vla-put-textalignmentpoint newobj (vla-get-textposition x))
                 (vla-put-stylename newobj (vla-get-textstyle x))
                 (vla-put-height newobj (* (vla-get-scalefactor x) (vla-get-textheight x)))
                 (vla-put-layer newobj (vla-get-layer x))
                 (vla-put-color newobj (vla-get-textcolor x))
                 (vla-put-rotation newobj (get_angle x))
               (prompt (strcat "\nERROR replaceing dimtext " str))
« Last Edit: January 21, 2006, 08:25:05 AM by CAB »
« Reply #34 on: January 20, 2006, 10:11:28 PM »
Jeff,
Nice job I added one line of code and it worked perfectly.  :-)
« Reply #35 on: January 20, 2006, 10:59:52 PM »
Thanks, Alan....that's what happens when I start my code with code I ganked from someone else's (namely, Tim's first posting)....I never use that method of going through the selection set, and I know that he does, I dunno why I didn't catch that.  :oops:
« Reply #36 on: January 20, 2006, 11:51:30 PM »
No problem.
Looking ay the code.
You could go directly to the substitution with chr.
  (setq new (vl-string-subst (chr (atoi (substr txt (+ 3 pos) 3)))
                                     (substr txt (+ 1 pos) 5) txt))
        (ssdel ent ss)
Crank
« Reply #37 on: January 21, 2006, 02:13:00 AM »
Can't you use Unicodes?
%%130 -> \U+0082
I was thinking of something like this:
(defun c:FixDimText (/ ss Ent obj txt pos code new dec2hex)
(defun dec2hex (value / num n1 n2 L)
(setq num (atoi value))
(setq L '("0" "1" "2" "3" "4" "5" "6" "7" "8" "9" "A" "B" "C" "D" "E" "F"))
(setq n2 (- num (* (setq n1 (/ num 16)) 16)))
(setq value (strcat (nth n1 L)(nth n2 L)))
(setq new (vl-string-subst (strcat "\\U+00" (dec2hex (substr txt (+ 3 pos) 3)))
                           (substr txt (1+ pos) 5) txt))
(ssdel ent ss)
(Not tested)
deegeecees
« Reply #38 on: January 21, 2006, 10:46:56 AM »
I hope you didn't sneeze on the code I copied.  :-D Get better Mr. B.
Actually you guys ROCK! I didn't expect a call to arms such as this. I've got TONS of work to do, no time right now to test these, so it'll be on the back burner 'til Monday or possibly later today. Thankyou for the help.
deegeecees
« Reply #39 on: January 23, 2006, 04:27:28 PM »
%%130 -> \U+0082
These seem to work, how do I get the conversions?
deegeecees
« Reply #40 on: January 23, 2006, 04:32:21 PM »
This worked like a charm! Thanks again everybody.
Crank
« Reply #41 on: January 23, 2006, 08:30:32 PM »
%%130 -> \U+0082
Convert the decimal value to hexadecimal.
Tip: Use CALC (windows calculator on scientific) to convert on the fly.
