Author Topic: How to lock a drawing before leaving ...  (Read 7418 times)
Hangman
Re: How to lock a drawing before leaving ...
« Reply #15 on: March 02, 2010, 10:28:44 AM »
So the basic consensus for this dilemma is to use password protect.
No, not for me. It's education.
If you can't convince them to behave perhaps consider making an archive copy before you leave work.
You should know I agree with what you all have said.  Education is the key.  And the drawings SHOULD be backed up every day.  The problem lies in that these guys were misinformed from the setup and they have been practicing a really bad habit.
To tell you the story, I've been here only a short period of time.  Before I came, the most knowledgeable person for autocad had about a years worth of experience.  Before autocad was installed, they were using microstation and their IT and support people were out of state.  Everything was done over the wire.
So they purchased autocad and had someone come in and show them how to use it.  This person taught them what he knew, but unfortunately, if he is only there for a paycheck, then he passes the ill-given information on to those he works with.  So now there are 15 users who are trying to follow what this one person taught them to do and making a mess.  Not to mention over half really don't like autocad, they are used to microstation.  And when commands don't work like microstations commands, they get even more infuriated at it.
So, past practices are to check out a project.  When they are done, check the project back in.  Unfortunately, they were taught by this guy who set up everything that when they check out a project, save it the C: drive.
So much for the server doing it's nightly backup.
As for the user who is changing the drawings when he should be saving it out as another before working on it or copying something from it, I would think he's already proven himself to the upper management.  They are happy with him, so he can just float along now.  He knows he won't get put out on the back porch.
So I'm trying - without stepping on toes & burning any bridges - to right a wrong they have been practicing for about a year.  It is going to be a long, slow process.
Just to give you an idea of where they are, in my meeting Monday morning, they learned two fantastic commands;  QSELECT and ALIASEDIT.
Thanks guys for your listening ear & your help.
Hangman  8)
Drafting Board, Mechanical Arm, KOH-I-NOOR 0.7mm
« Reply #16 on: March 02, 2010, 10:37:54 AM »
Sounds like that company won't last too long...  :|
Hangman
« Reply #17 on: March 02, 2010, 11:11:00 AM »
Actually, they have been around for quite some time, and (from an insiders point of view) they won't be going away any time soon either.  They are very well established and quite necessary.  I won't give any names, but I will say this;  The country would be in a bit of a fix without them.
I know what your asking; How in the world did they get along with only 15 drafters & why don't they have a more skilled CAD tech person ??   Well, like I said, they used microstation for decades, all their standards were set and they had no deviation from it.  But the company has recently split (split is not the correct terminology here, because they are still one company, but because of federal regulations, it was a necessary step) and these guys I'm with now, because of client demand and other developments, has decided to go with Autocad.  I just need to get these guys up to par.
Hangman  8)
t-bear
« Reply #18 on: March 02, 2010, 11:52:46 AM »
Have you considered doing a "Lunch-N-Learn?"  Twice a week, they bring a sack lunch and you "instruct" them for a half hour on proper ACAD etiquette. A side effect of this is that the more lunch breaks they lose in class, the faster they are going to implement what you're teaching.  The heard heads get extra toutoring until they come on board.
you would have to get management on board, but showing them the number of lost billable hours the present situation is costing should be an incentive.....
Hangman
« Reply #19 on: March 02, 2010, 12:10:12 PM »
That has been suggested and I do have the approval of management.  (I had to show off a little in my monday morning meeting, but I impressed them enough to get a little pull).
It's just a matter of time now.  I'm hoping I can start the "Lunch N Learn" by next week, but I've gotta be honest, if they are just learning simple commands like QSELECT, It's going to take awhile to get the herd going in the right direction.
I was talking with one of the engineers earlier who mentioned they've had one of those week long contracting type training sessions, but that was it.  And it was a year ago so most of them don't even remember it.
Hangman  8)
Bob Wahr
« Reply #20 on: March 02, 2010, 12:25:18 PM »
Not surprising at all.  You have to use it after you are shown it and with no one around to reinforce it, the information will fade away.  I disagree with Lee Mac about the company failing.  I've been through similar though not as bad before and it will work out.  My suggestions are to not try to teach too much in a chunk.  Give them something that they can use instantly that will make them happy, then give them a week to use it before you drop the next thing or two on them.  Try to get the company to bring in pizza or subs or something.  If they have to both spend their lunch hour on it, and supply their own food, interest will fade quickly.  If management doesn't like the idea, try to bargain for them picking it up at least once a month.  Teach them things that you see they need, but don't limit it to that.  Ask for suggestions.  Ask them what microstation commands/functionality they are missing, and show them how to do it in AutoCAD.  It is really easy to let your brain close down due to the dislike of one CAD package or the other.  An analogy I have used that might help them twist their brains around it better is the calculator.  To me, the difference between using AutoCAD and Microstation is the same as the difference between a standard and RPN calculator.  They both take in the same information and yield the same results, you just have to think a little differently to get there.
Hangman
« Reply #21 on: March 02, 2010, 12:35:25 PM »
Excellent advice, Thank you Bob.
Hangman  8)
cmwade77
« Reply #22 on: March 02, 2010, 03:00:35 PM »
After reading more about your situation, I would also say education is the key, but keep in mind the local laws, for example in California, you must give at least a 30 minute lunch for an 8 hour shift, so be careful how you handle the lunch and learn and make sure it complies with your laws, but it is a good idea.
In addition, I would say that based on what you have said here, you need to get management to approve two full day sessions (preferably consecutively) to get them on the correct practices.
Alternatively use Windows SteadyState (Free) and prevent them from saving to their C drive at all (depending on the company, this may require getting IT involved, but it will be worth it in the long run). This will prevent them from being able to check out a project by copying it to their C drive.
You need to have the authority to at least recommend that they be disciplined, perhaps even fired if they don't follow the guidelines set forth. Also, make sure that there are documented CAD Standards in a manual, I recommend using a program to create it as a website, so that it can be modified over time as standards evolve, it should never be printed under any circumstances, it risks becoming outdated very quickly that way.
Hangman
« Reply #23 on: March 03, 2010, 02:47:48 PM »
I thank you all for your advice, comments, and concerns with this issue.  I really do appreciate it and I will be working toward the end goal as you have suggested, that of being educated.  Who knows, some of these people may end up coming to work with you or for you in some manner.  So again, I thank you.
So, sliding back to my original question, now more out of curiosity rather than a solution, ...
I don't know that creating a routine to lock a drawing has ever been accomplished yet.  Perhaps I have missed something in my search, but I haven't found anything yet.
But I think it would be kind of cool to be able to use the security feature of acad and lock a drawing, but as the user types the password in, it is also posted to a document on the server for CAD support or IT support to access if need be.
Accessing the security feature I think is the trick here.  Because the password can be put to a local variable, it can be easily printed to a document (Word, Excel, Notepad, etc.) on the server for safe keeping.
Anyone want to venture into this ??   I don't know where or how the security feature works in terms of the info.  Is it a registry item ??  If so, does it have to be unlocked from the same machine it was locked from ??  Is it stored locally with the drawing ??  If so, can this be manipulated by LiSP or VLA ??
I know curiosity killed the cat, but A: it had nine lives, and B: satisfaction brought it back.  :D
Thank you all.
Hangman  8)
nivuahc
« Reply #24 on: March 03, 2010, 03:14:13 PM »
Password protected drawings was one of the absolute worst decisions (in my opinion) that Autodesk made. One of, not the worst, but right up there.
Before you go down this route, it might be in your best interest to contact Autodesk and ask them how to recover or remove the password from a password protected drawing. The answer you get may change your mind about persuing this avenue at all.
« Reply #25 on: March 03, 2010, 03:20:56 PM »
FULLY AGREE
Open that can of worms by using it to strong arm control a situation that should be dealt with by policy and education and forever regret it.
CTMill
« Reply #26 on: March 03, 2010, 05:10:37 PM »
I agree with everyone else....  Password protection sounds like a good idea.  But is it really the best idea?  Imo, education has always been the best method to cure this kind of problem.  Think of it this way:
Let's say the guy, who is floating along, decides to complain to the boss because you locked him out of a drawing.  Now you're preventing him from being able to work.  You could be perceived as the bad guy in the eyes of the boss and IT.  And that's without even taking into account who has more pull......
Civ3d/A2K16
« Reply #27 on: March 03, 2010, 05:12:37 PM »
I didn't realise it was considered that bad - is it that you cannot recover a drawing for which you have lost a password?
« Reply #28 on: March 03, 2010, 05:19:18 PM »
Thats's part of it.
.. and consider the possibility of malicious damage by a malcontent.
[side issue] how good is <your> backup system.
Bob Wahr
« Reply #29 on: March 03, 2010, 07:06:20 PM »
My vote, if you absolutely need to lock it, is still for setting the folder attributes to Read Only.
