Author Topic: extended DATA  (Read 2522 times)
Andrea
extended DATA
« on: March 23, 2005, 01:52:08 PM »
Hi all,
I'm trying to get specific extended data of an entity.
and redefine it...
But i'm not specialiste in XDATA.
can anyone give me some hint ?
or sample ?
thanks
Keep smile...
Andrea
extended DATA
« Reply #1 on: March 24, 2005, 09:56:21 AM »
no answer ?
       :cry:
Keep smile...
daron
extended DATA
« Reply #2 on: March 24, 2005, 02:18:49 PM »
You most likely won't get a lisp answer in the CAD General forum.
Jimmy D
extended DATA
« Reply #3 on: March 25, 2005, 07:04:09 AM »
Hi Andrea,
I have just done some programming using xdata. I had a hard time as well trying to figure it out. This is what I could make of it.
To make xdata you have first make a 'regapp' call. In my case it was something like this:
(regapp "JIDH-XDATA")
When the xdata is made (as in your case) and you want to retrieve it, you need to make a call to that name that was passed to regapp:
(ssget "X" '((-3 ("JIDH-XDATA"))))
-or
(entget (car (entsel))'("JIDH-XDATA"))
So I think that you first of all need to know the regapp-name that was given to the xdata by the application.[/quote][/code]
extended DATA
« Reply #4 on: March 25, 2005, 07:51:09 AM »
Jimmy D
extended DATA
« Reply #5 on: March 25, 2005, 08:12:01 AM »
I'm not sure Mark, but I thought XRecords were not attached to entities?
I use Xdata to attach additional data to an object that I can retrieve later when this object is selected.
Is that also possible with Xrecords?
extended DATA
« Reply #6 on: March 25, 2005, 09:26:38 AM »
You can "attach" xrecords to an entity by adding an extension dictionary to the entity (read about GetExtensionDictionary method), then adding the xrecords to the extension dictionary.
