Here is one I just updated, it was also written back in 2003
This routine will Freeze the layer of a selected entity in ALL tabs
and ALL viewports except the active viewport
If you run the routine in model space it will freeze in ALL viewports
;;; vpf.lsp Viewport Layer Freeze
;;; ARGUMENTS
;;; none
;;; USAGE
;;; vpf
;;; PLATFORMS
;;; 2000+
;;; AUTHOR
;;; Copyright© 2005 Charles Alan Butler
;;; ab2draft@TampaBay.rr.com
;;; VERSION
;;; 3.1 Jan 28, 2005
;;; This routine will Freeze the layer of a selected entity in ALL tabs
;;; and ALL viewports except the active viewport
;;; If you run the routine in model space it will freeze in ALL viewports
;;; YOU MAY USE THIS CODE ONLY FOR *NON-COMMERCIAL*
;;; PURPOSES AND ONLY IF YOU RETAIN
;;; THIS HEADER COMPLETE AND UNALTERED
;;; you must contact me if you want to use it commercially
;;====== Main Lisp Routine =======
(defun c:vpf (/ oldcmd vpflag sel-vport entvport pik str laylist ms)
;; error function
(defun *error* (msg)
(if (not (member msg
'("console break" "Function cancelled" "quit / exit abort"))
(princ (strcat "\nError: " msg))
) ; if
(if (/= laylist "")
(if ms
(command "-layer" "thaw" laylist "")
(command "vplayer" "t" laylist "All" "" ; reset selectd layers
"pspace")
(setvar "CMDECHO" oldcmd)
) ;end error function
(setq oldcmd (getvar "CMDECHO"))
(setvar "CMDECHO" 0)
(if (= (getvar "TileMode") 1) ; in model space
(prompt "\n**** Layers chosen will be frozen in all viewports.")
(setq ms t)
(progn ;else in a layout
(setq vpflag (getvar "cvport")) ; get viewport #
(while (= vpflag 1) ; No active viewport, Loop until one is picked
(setq sel-vport (car (entsel "\nSelect view port: ")))
(if (= sel-vport nil)
(alert
"You must select a viewport\n --=< Try again! >=--"
(setq entvport (entget sel-vport))
(if (= (cdr (assoc 0 entvport)) "VIEWPORT")
(setq vpflag (cdr (assoc 69 entvport))
(command "mspace")
(setvar "cvport" vpflag)
) ; endif viewport
) ; endif cond sel-vport
) ;endwhile (= vpFlag 1)
) ; endif
;; Get Entity and Freeze Layer
(setq laylist "") ; initialize our layer list
(command "undo" "begin")
(setq pik (nentsel "\nSelect an item whose layer to freeze: "))
(while pik
(setq
laylist (strcat laylist (cdr (assoc 8 (entget (car pik)))) ",")
;; Freeze selected layers for visual feedback
(setq str (cdr (assoc 8 (entget (car pik)))))
(if ms
(if (= str (getvar "clayer"))
(alert "Layer current, will be frozen in viewports.")
(command "-layer" "freeze" str "")
(command "vplayer" "f" str "All" "")
((and ms (/= laylist "")) ; Freeze layers in ALL viewports and ALL TABs
(setvar "TileMode" 0) ; Force Paper Space
(command "vplayer" "f" laylist "All" "")
(setvar "TileMode" 1) ; Back to Model Space
((/= laylist "") ; Freeze layers in ALL viewports and ALL TABs
(command "vplayer" "t" laylist "Current" "") ; restore working VP
) ; end cond stmt
(command "undo" "end")
) ; end defun
(prompt "\nType VPF to run")
(prin1)
