I've created a load of blocks for use in our every day work.
I've created all the blocks on layer zero and set the colour to byblock.
When I insert them into the drawing, the blocks are shown on the layer I inserted them on, and when I freeze that layer the attributes disappear.
Except when I DWF the drawings that is. Then when I freeze the corresponding layer the attributes are shown as being on layer 0, and are still on.
How do I set the attributes so they are controlled by the same layer as the block?
