Author Topic: Mtext reactor to change textsize...  (Read 2088 times)
Shade
« on: July 26, 2007, 10:15:52 AM »
How does one set the textsize system variable with activeX.
I am writing a reactor for the mtext command to change the layer to 'Notes' and the Textsize as per the dimscale.
I figured out how to set the layer and retrieve the dimscale, but i am lost on how to set the textsize variable?
Any help would be appreciated.
Re: Mtext reactor to change textsize...
« Reply #1 on: July 26, 2007, 10:18:16 AM »
Use the document's SetVariable method.
Shade
« Reply #2 on: July 26, 2007, 10:28:19 AM »
I didn't see an <ActiveTextSize> variable in the Active document properties.?
Does one have to set the <ActiveTextStyle> <LastHieght> in order to set the textsize variable.
If one does I see more potential in this route then just a system variable.
« Reply #3 on: July 26, 2007, 11:20:58 AM »
You could use this to set the height for all new text objects:
(if (not (zerop (getvar 'dimscale)))
  (setvar 'textsize (* (getvar 'dimscale) 0.125))
But if the text already exists, you are going to have to use something like (vla-put-height obj #).
Ron
mkweaver
« Reply #4 on: July 27, 2007, 08:56:47 AM »
The system variable is "TextSize"
