This is for the old guys. I've begun working at a university. My job is to go through all the drawings in the flat files which date as old as 1908, organize them and put info into a database. The question is this; what do you call the paper that was printed on the back side to show up on the front? The paper looks like a mix between mylar and vellum, but is thicker, brown (probably due to age), and if you put the slightest crease in it it leaves a white mark, similar to plastic. What is this stuff? Sorry, no picture.
