Author Topic: AutoCAD Puzzle  (Read 2428 times)
Lerner
AutoCAD Puzzle
« on: February 01, 2010, 11:21:26 PM »
Here's an interesting little puzzle I just came up with. Might be easy for some but stump others. Open the attached drawing. It contains a simple line. Now do an ID on the endpoints. You get X = 0.0  Y = 0.0 Z = 0.0 on the left and X = 1.0 Y = 0.0 Z = 0.0 on the right. Now select the line and look at the properties palette. That tells you Start X = 0 Start Y = 0 Start Z = 0 and End X = 1 End Y = 0 End Z = 0.1. What's going on?
Until people have a chance to look at it, maybe just say if you solved it and not give the solution right away.
« Last Edit: February 01, 2010, 11:26:35 PM by Lerner »
Serge J. Gianolla
Re: AutoCAD Puzzle
« Reply #1 on: February 01, 2010, 11:41:26 PM »
I have to say you are a cheeky boy Lerner :evil:
Willie
  • Going nowhere slowly
Re: AutoCAD Puzzle
« Reply #2 on: February 02, 2010, 12:03:58 AM »
to easy
Soli Deo Gloria | Qui Audet Adipiscitur
Windows 8  64-bit Enterprise | Civil 3D 2015 and 2016| ArcGIS 10.1
Yogi Berra : "I'd give my right arm to be ambidextrous."
Bob Wahr
Re: AutoCAD Puzzle
« Reply #3 on: February 02, 2010, 01:32:22 AM »
alternate selection techniques kill the fun
Willie
Re: AutoCAD Puzzle
« Reply #4 on: February 02, 2010, 01:38:45 AM »
JIP
Re: AutoCAD Puzzle
« Reply #5 on: February 02, 2010, 01:43:19 AM »
I'm afraid I was naughty .. didn't read the instructions properly.
Hit Q ( alias for LIST)  enter < select crossing >
 :oops:
