Author Topic: How do I set attribute values after inserting an external block  (Read 6925 times)
kaefer
Re: How do I set attribute values after inserting an external block
« Reply #15 on: June 02, 2013, 02:40:18 PM »
For example creating generic functions for SymbolTables then more specific for each of the Tables derived from SymbolTable,
Funny you should mention that. Since SymbolTableRecord doesn't implement IEnumerable, but its dependents are expected to, we could use this loophole.
Code - vb.net: [Select]
  1.         <ExtensionAttribute()>
  2.         Public Iterator Function GetObjects(Of T As DBObject)(str As SymbolTableRecord) As IEnumerable(Of T)
  3.             For Each objectId As ObjectId In CType(str, IEnumerable)
  4.                 Dim target As T = TryCast(objectId.GetObject(OpenMode.ForRead, False, False), T)
  5.                 If target IsNot Nothing Then
  6.                     Yield target
  7.                 End If
  8.             Next
  9.         End Function
Gasty
« Reply #16 on: June 02, 2013, 06:39:27 PM »
The Yield statement  only exists in VB 11 .NET 4.5.
Gaston Nunez
Jeff H
« Reply #17 on: June 04, 2013, 01:29:35 AM »
Gaston Nunez
Also 4.0, 3.5, 3.0 &2.0
  6.                     Yield target
  7.                 End If
  8.             Next
  9.         End Function
BlockTableRecord implements IEnumarable, and that's the only SymbolTableRecord off the top of my head I can think of that is a "container"
TheMaster
« Reply #18 on: June 04, 2013, 02:50:12 PM »
Certain people abhor passing a non-generic sequence to a functon which will produce run-time
errors when fed an argument of the wrong type, like string (IEnumerable of char), when a sequence of ObjectId  is expected. Make it an overload of the specific class.
Yes, I suppose that would be me.  I don't see it as being any different than typing an argument as System.Object, when only certain specific types are applicable.
« Last Edit: June 05, 2013, 07:05:46 AM by TT »
Jeff H
« Reply #19 on: June 04, 2013, 07:12:44 PM »
To be fair and should of mentioned from early post I made
http://www.theswamp.org/index.php?topic=44641.msg499207#msg499207
To thank Tony as it was from comments in a example posted by Tony or how I understood what he was saying. Might have misunderstood his intent, but all I remember it threw an error if it was not derived from SymbolTableRecord and advised to create others for each of the different tables.
