Author Topic: Double Click in a List_Box  (Read 13462 times)
Andrea
Re: Double Click in a List_Box
« Reply #15 on: September 09, 2009, 01:15:19 PM »
Andrea, is ObjectDCL part of your company?
Yes,..OpenDCL is a derivate product of ObjectDCL (the original)
Keep smile...
jbuzbee
« Reply #16 on: September 09, 2009, 01:32:14 PM »
OpenDCL is very easy to learn.  Great support over at OpenDCL.com at the discussion forums and lots of tutorials and examples.  The team is dedicated to keeping it in continual development.  And it's free.  Do a search here - I've posted some stuff.  Defenitely check it out.
jb
James Buzbee
Windows 8
« Reply #17 on: September 09, 2009, 01:33:04 PM »
Thanks mate,
Will definitely check it out.
I see quite a few downloads on the OpenDCL site, should I get:  OpenDCL.Runtime.6.0.0.3.msi?
Crank
« Reply #18 on: September 09, 2009, 01:57:56 PM »
[...] should I get:  OpenDCL.Runtime.6.0.0.3.msi?
You need OpenDcl.Studio
« Reply #19 on: September 09, 2009, 02:02:59 PM »
Ahh... thanks Mr Crank  :-)
johnson
« Reply #20 on: May 04, 2011, 12:04:40 PM »
Haven't tried your most recent post yet - but I had a dabble with this:
(defun c:test (/ mylist dcl_id ptr acptr)
  (createleemacdialog)
  (setq dcl_id (load_dialog (strcat (getvar "SAVEFILEPATH") "test.dcl")))
  (if (not (new_dialog "test" dcl_id))
    (exit)
  (setq mylist (list "Electrical" "Structural" "Plumbing" "Foundation"))
  (start_list "LB1" 3)
  (mapcar 'add_list mylist)
  (end_list)
  (action_tile "accept" "(or (and acPtr
                                  (not (alert (nth (atoi acPtr) mylist)))
                                  (not (setq acPtr nil)))
                             (done_dialog))")
  (action_tile "LB1"    "(or (and (eq ptr $value)
                                  (not (setq acPtr ptr ptr nil)))
                             (setq ptr $value))")
  (action_tile "cancel" "(done_dialog)")
  (start_dialog)
  (unload_dialog dcl_id)
(defun createleemacdialog (/ dialf)
  (setq dialf (open (strcat (getvar "SAVEFILEPATH") "test.dcl") "w"))
  (write-line
    "test  : dialog {
          label = \"test double click\" ;
: column {
: spacer {}
: boxed_column {
: spacer {}
label = \"ListBox :\";
: list_box {
        key = \"LB1\";
        allow_accept = true;
: spacer {}
        : text {
        label = \"For LeeMac + Andrea Only ! ;-)\";
        : row {
  children_alignment =
: spacer {}
        ok_cancel ;
"   dialf
  (close dialf)
nice one.we can use command also?lee....like copy text(replaced by that "Electrical" "Structural" "Plumbing" "Foundation")  double click means copy commend should active.....possible?
« Reply #21 on: May 04, 2011, 12:15:11 PM »
Many things are possible.  :-)
johnson
« Reply #22 on: May 04, 2011, 08:49:19 PM »
can you say for sample?i have tried with this.but this one autocad alert box.so command is not support.
Stefan
  • The most I miss IRL is the Undo button
« Reply #23 on: May 05, 2011, 02:52:06 AM »
Hi Lee
I just saw how old is original post... sorry if it is not actual anymore
Anyway, another method for double-click for your example
  (action_tile "accept" "(done_dialog)")
  (action_tile "LB1"    "(if (= $reason 4)
                               (alert (nth (atoi $value) mylist))
Note that is working no matter how allow_accept is set..
« Reply #24 on: May 05, 2011, 08:02:40 AM »
(= $reason 4)
How could I have missed that all this time...
Thanks phanaem, appreciated.
« Reply #25 on: May 05, 2011, 08:29:17 AM »
The functionality you are looking for could probably be achieved using the allow_accept attribute, since the command would be started using the same action as the accept tile.
Example:
([color=BLUE]defun[/color] c:test ( [color=BLUE]/[/color] *error* coms dch file ok tmp )
  [color=GREEN];;----------------------------------------------;;[/color]
  [color=GREEN];; Example by Lee Mac 2011  -  www.lee-mac.com  ;;[/color]
  ([color=BLUE]defun[/color] *error* ( msg )
    ([color=BLUE]if[/color] ([color=BLUE]and[/color] dch ([color=BLUE]<[/color] 0 dch)) ([color=BLUE]unload_dialog[/color] dch))
    ([color=BLUE]if[/color] ([color=BLUE]and[/color] tmp ([color=BLUE]setq[/color] tmp ([color=BLUE]findfile[/color] tmp))) ([color=BLUE]vl-file-delete[/color] tmp))
    ([color=BLUE]if[/color] ([color=BLUE]and[/color] msg ([color=BLUE]not[/color] ([color=BLUE]wcmatch[/color] ([color=BLUE]strcase[/color] msg) [color=MAROON]"*BREAK,*CANCEL*,*EXIT*"[/color])))
      ([color=BLUE]princ[/color] ([color=BLUE]strcat[/color] [color=MAROON]"\n** Error: "[/color] msg [color=MAROON]" **"[/color]))
    ([color=BLUE]princ[/color])
  ([color=BLUE]setq[/color] coms
      [color=MAROON]"LINE"[/color]
      [color=MAROON]"CIRCLE"[/color]
      [color=MAROON]"ELLIPSE"[/color]
      [color=MAROON]"XLINE"[/color]
      [color=MAROON]"PLINE"[/color]
      [color=MAROON]"POLYGON"[/color]
      [color=MAROON]"ARC"[/color]
      [color=MAROON]"POINT"[/color]
  ([color=BLUE]cond[/color]
        ([color=BLUE]and[/color] ([color=BLUE]setq[/color] file ([color=BLUE]open[/color] ([color=BLUE]setq[/color] tmp ([color=BLUE]vl-filename-mktemp[/color] [color=BLUE]nil[/color] [color=BLUE]nil[/color] [color=MAROON]".dcl"[/color])) [color=MAROON]"w"[/color]))
          ([color=BLUE]progn[/color]
            ([color=BLUE]write-line[/color]
                [color=MAROON]"com : dialog { label = \"Commands\"; spacer; "[/color]
                [color=MAROON]"  : list_box { key = \"lst\"; alignment = centered; allow_accept = true; } ok_cancel; }"[/color]
              file
            ([color=BLUE]<[/color] 0 ([color=BLUE]setq[/color] file ([color=BLUE]close[/color] file) dch ([color=BLUE]load_dialog[/color] tmp)))
          ([color=BLUE]new_dialog[/color] [color=MAROON]"com"[/color] dch)
      ([color=BLUE]princ[/color] [color=MAROON]"\n--> Error Loading Dialog."[/color])
    ([color=BLUE]t[/color]
      ([color=BLUE]start_list[/color] [color=MAROON]"lst"[/color])
      ([color=BLUE]mapcar[/color] '[color=BLUE]add_list[/color] ([color=BLUE]setq[/color] coms ([color=BLUE]acad_strlsort[/color] coms))) ([color=BLUE]end_list[/color])
      ([color=BLUE]setq[/color] *com ([color=BLUE]set_tile[/color] [color=MAROON]"lst"[/color] ([color=BLUE]cond[/color] ( *com ) ( [color=MAROON]"0"[/color] ))))
      ([color=BLUE]action_tile[/color] [color=MAROON]"lst"[/color] [color=MAROON]"(setq *com $value)"[/color])
      ([color=BLUE]setq[/color] ok ([color=BLUE]start_dialog[/color]))
  (*error* [color=BLUE]nil[/color])
  ([color=BLUE]if[/color] ([color=BLUE]=[/color] 1 ok) ([color=BLUE]command[/color] ([color=BLUE]strcat[/color] [color=MAROON]"_."[/color] ([color=BLUE]nth[/color] ([color=BLUE]atoi[/color] *com) coms))))
johnson
« Reply #26 on: May 05, 2011, 11:02:32 AM »
Example:
              file
lee our lisp commands is not supporting here!!???its supporting only cad commands.why?
« Reply #27 on: May 05, 2011, 12:49:11 PM »
Because the code was designed for AutoCAD commands, not LISP functions.
johnson
« Reply #28 on: May 05, 2011, 08:55:11 PM »
how can modify this for lsp commands lee
« Reply #29 on: May 06, 2011, 06:39:03 AM »
You would have to change the line:
  (if (= 1 ok) (command (strcat "_." (nth (atoi *com) coms))))
To call the LISP function instead, something like:
  (if (= 1 ok) (eval (read (strcat "(c:" (nth (atoi *com) coms) ")"))))
