Author Topic: ribbon button external command  (Read 1783 times)
sybold
« on: August 13, 2012, 01:53:02 AM »
hello,
in 2012 i have a ribbon with commands being loaded from a separated dll.
in 2013 i can't get it to work anymore.
2012 code, for 2013 i changed acad.exe to accore.dll
my ribbon shows up fine, all local commands work like they should, only the commands being loaded from a separated dll don't.
in 2012 all works fine.
Public Class AdskCommandHandler
    Implements System.Windows.Input.ICommand
    <DllImport("acad.exe")> _
    Private Shared Sub acedPostCommandPrompt()
    Public Function CanExecute(ByVal parameter As Object) As Boolean Implements System.Windows.Input.ICommand.CanExecute
        Return True
    End Function
    Public Event CanExecuteChanged As EventHandler Implements System.Windows.Input.ICommand.CanExecuteChanged
    Public Sub Execute(ByVal parameter As Object) Implements System.Windows.Input.ICommand.Execute
        Dim ribBtn As RibbonButton = TryCast(parameter, RibbonButton)
        If ribBtn IsNot Nothing Then
            Dim sCmd As String = String.Empty
            Dim sSubCmd As String = String.Empty
            Dim bLoadAssy As Boolean = False
            If ribBtn.CommandParameter.ToString.IndexOf("|").CompareTo(-1) Then
                Dim cmdParams() As String = ribBtn.CommandParameter.ToString.Split("|")
                sCmd = cmdParams(0)
                sSubCmd = cmdParams(1)
                bLoadAssy = True
            Else
                sSubCmd = ribBtn.CommandParameter
            End If
            If bLoadAssy Then LoadAssembly(sCmd)
            acApp.DocumentManager.MdiActiveDocument.SendStringToExecute(sSubCmd, True, False, True)
        End If
    Private Shared Sub LoadAssembly(ByRef AssemblyName As String)
        Dim app_Path As String = My.Application.Info.DirectoryPath & "\Tools\"
        Dim oLoader As ExtensionLoader = Nothing
        If Not ExtensionLoader.IsLoaded(app_Path & AssemblyName) Then
            ExtensionLoader.Load(app_Path & AssemblyName)
        End If
End Class
button that doesn't work, CommandParameter has the value of the dll and the command
the dll exists in the  tools directory.
        Dim ribbuttonbig3 As RibbonButton = New RibbonButton
        ribbuttonbig3.IsToolTipEnabled = True
        ribbuttonbig3.ToolTip = "save document metadata to sql"
        ribbuttonbig3.Orientation = Windows.Controls.Orientation.Vertical
        ribbuttonbig3.LargeImage = LoadImage(My.Resources.VSHDPD)
        ribbuttonbig3.Size = RibbonItemSize.Large
        ribbuttonbig3.Text = "Savetodpd"
        ribbuttonbig3.CommandParameter = "DPD.dll|savetodpd "
        ribbuttonbig3.ShowText = True
        ribbuttonbig3.Image = LoadImage(My.Resources.VSHDPD16)
        ribbuttonbig3.CommandHandler = New AdskCommandHandler()
any idea's?
Re: ribbon button external command
« Reply #1 on: August 13, 2012, 01:56:36 AM »
Is that your 2013 code?
sybold
« Reply #2 on: August 13, 2012, 02:48:29 AM »
