Author Topic: AEC messgae  (Read 4209 times)
Coder
AEC messgae
« on: January 05, 2012, 03:24:53 AM »
Hello guys .
Sometimes when I am trying to save as a copy of a drawing to old version of Autocad  I receive a message says " which means" This
would create or add AEC objects to the drawing , and after that I noticed if I copy and past objects inside the same drawing it would
take a very long long long time to proceed the action.
Besides all of that , the size of the drawing would be increased each time open and close the drawing .
How to purge or delete these AEC objects from the drawing ?
Many thanks .
pBe
Re: AEC messgae
« Reply #1 on: January 05, 2012, 08:26:19 AM »
DXFOUT works for me
trogg
Re: AEC messgae
« Reply #2 on: January 05, 2012, 10:01:44 AM »
try the command
-EXPORTTOAUTOCAD <enter>
and then follow the prompts...
This will make a new version (copy) of your drawing that still has all your objects - they simply don't have the AEC baggage that comes along with them.
Note: In AutoCAD, don't forget the minus sign before the command...
cmwade77
Re: AEC messgae
« Reply #3 on: January 05, 2012, 06:22:50 PM »
Better still use DWGconvert and process all drawings for that project at once. I know this command is in 2012 and possibly in 2011 as well.
alanjt
  • Standby for witty remark...
Re: AEC messgae
« Reply #4 on: January 05, 2012, 10:40:20 PM »
  :kewl:
Dropbox
Coder
Re: AEC messgae
« Reply #5 on: January 06, 2012, 05:48:37 AM »
Thank you all guys .
Isn't there a programming solution for that problem without exporting to another drawing ?
Thanks so much
cmwade77
Re: AEC messgae
« Reply #6 on: January 06, 2012, 12:49:04 PM »
Not a reliable one that I have found.
Nibster
Re: AEC messgae
« Reply #7 on: January 06, 2012, 01:34:26 PM »
can't you manipulate files with lisp?  AECTOACAD command exports a cleaned drawing to the same folder with a preset prefix (or suffix)
BlackBox
Re: AEC messgae
« Reply #8 on: January 06, 2012, 03:05:52 PM »
_AecExportToAutoCAD20##:?
Example:
(command "_AecExportToAutoCAD2007")
Edit to add - This works for both Land Desktop Companion 2009, and Civil 3D 2010-2012; tested using LDC 2009, and C3D 2011.
Nibster
Re: AEC messgae
« Reply #9 on: January 06, 2012, 03:29:50 PM »
in 2012 it's just as i typed up above.  it exports according to whatever version you're using
BlackBox
Re: AEC messgae
« Reply #10 on: January 06, 2012, 03:37:04 PM »
... Hence my suggestion, Nibs. :wink:
From first post:
Sometimes when I am trying to save as a copy of a drawing to old version of Autocad  I receive a message says ...
Nibster
Re: AEC messgae
« Reply #11 on: January 06, 2012, 03:46:15 PM »
ah! darn that short term memory retention... :lol:
BlackBox
Re: AEC messgae
« Reply #12 on: January 06, 2012, 03:51:05 PM »
 :angel:
Matt__W
  • I like my water diluted.
Re: AEC messgae
« Reply #13 on: January 06, 2012, 04:46:17 PM »
AECTOACAD gives you options to bind xrefs, version, etc...
Autodesk Expert Elite
BlackBox
Re: AEC messgae
« Reply #14 on: January 06, 2012, 04:56:02 PM »
I did not know that - so I tried it - and the AecToAcad command also works back on LDC 2009 (oldest version I have)... I had no clue! Never used the command before today.  :oops:
I appreciate the clarification, Matt (sorry Nibs!). LoL :beer:
