Author Topic: How do I get a pathname back from a listbox  (Read 4727 times)
mkweaver
« on: April 09, 2009, 09:40:01 AM »
If I use:
(dcl_SelectFiles '("Drawings|*.dwg")"Select drawing files for list" (getvar "dwgprefix"))to get a list of files they come back, as expected, with "\\" as the folder delimiter.  If I then put that list into a listbox they display with a single backslash, again, as expected.  However, if I then pull that list from the listbox, they come back into lisp with a single backslash.
If I try to write the resulting string to a text file I get single backslash delimiters.  I tried the following code to replace the singles with doubles, but if the first character in a folder name happens to be a "t" then the backslash produces a tab character :-(  Not what I wanted.
(strcat
 (vl-list->string
   (subst (ascii "/") (ascii "\\") (vl-string->list line))
What am I missing here? There must be a way to do this.
Suggestions are appreciated.
Mike
owenwengerd
Re: How do I get a pathname back from a listbox
« Reply #1 on: April 09, 2009, 11:35:42 AM »
What exactly do you mean by "pull that list from the listbox"?  In lisp there is no "single backslash" in the way you use the term here.  You have either a "\\" character, or an escape character, but there is no such thing as a "\" character.  Therefore, I think the problem is further downstream.
jbuzbee
« Reply #2 on: April 09, 2009, 01:48:32 PM »
So Owen, if he uses a call like (I'm not at my computer so the sntax may not be right):
(dcl_ListBox_GetText(dcl_ListBox_GetCurSel mySAuperCoolListbox))
will return "C://My Documents//MyDrawing.dwg"  and not "C:\My Documents\MyDrawing.dwg"?
Again I'm not at my computer so I can't test this.  Just thinking out loud.  Nothing really anything better to do anyway.
James Buzbee
Windows 8
owenwengerd
« Reply #3 on: April 09, 2009, 03:04:34 PM »
(dcl_ListBox_GetText(dcl_ListBox_GetCurSel mySAuperCoolListbox))will return "C://My Documents//MyDrawing.dwg"  and not "C:\My Documents\MyDrawing.dwg"?
Actually it will return "C:\\My Documents\\MyDrawing.dwg"
mkweaver
« Reply #4 on: April 09, 2009, 10:14:58 PM »
I'm getting the entire contents of the listbox, thus:
(dcl_Control_GetList BuildDrawingListFromTxt_Form1_lbFiles)and the only thing I need to do is wrap each line in quotes.  So, I don't have a problem (other than I thought I had a problem).
Sorry for the disturbance :oops:
Owen and team, props for your work on ODCL.  This is so much better than vanilla dcl.
Thanks,
Mike
