Author Topic: ARX & VLX loaded from where?  (Read 2471 times)
« on: October 18, 2009, 12:17:31 AM »
I had some problems with ACAD2000 which I got straightened out but during the process
I noticed that the "plot2000 add on" I have is loaded from somewhere and I could not find
where it is being loaded. It has several support files loaded, an ARX, 2 VLX, 2 LSP.
I searched all the files in the main folder & the Support folder. (text files only, lsp mns etc)
Also searched the registry but only found path info there.
Where could it be?
FengK
Re: ARX & VLX loaded from where?
« Reply #1 on: October 18, 2009, 02:08:46 AM »
through appload? it should be shown in the registry though if this is the case. or maybe do a text search for "plot2000" in all the .lsp and .mnl files?
VovKa
  • Ukraine
« Reply #2 on: October 18, 2009, 03:37:10 AM »
is it here?
(vl-registry-descendents (strcat "HKEY_LOCAL_MACHINE\\" (vlax-product-key) "\\Applications"))
(vl-registry-descendents (strcat "HKEY_CURRENT_USER\\" (vlax-product-key) "\\Applications"))
if yes then delete it or set "LOADCTRLS" key to 0
« Reply #3 on: October 18, 2009, 09:55:00 AM »
That's where it was hiding.  "Plot2000"
Command: (vl-registry-descendents (strcat "HKEY_LOCAL_MACHINE\\"
("Wipeout" "Rtext" "Rectang" "QuikPik" "Plot2000" "PDFMAcad" "LsObj" "ISM"
"DOSLib" "CDG Purge" "AutoPlayer2000" "AutoCAD" "AText" "ASE-LPNTableRecord"
"AcetXPath" "AcetUtil" "AcetSysvDlg" "AcetPropulate" "AcetPackngo"
"AcetMoveBak" "AcetMocoro" "AcetLeadertools" "AcetLayWalk" "AcetLayTrans"
"AcetFullPath" "AcetFscreen" "AcetEditTime" "AcetDimsio" "AcetDCProps"
"AcetBattMan" "AcadWhoHas" "Acadvba" "AcadUnits" "AcadSummaryInfoUI"
"AcadSummaryInfo" "AcadStar" "AcadSolids" "AcadRender" "AcadRefEdit"
"AcadOrbit" "AcadOPM" "AcadOLEScale" "AcadMText" "AcadMatch" "AcadHyperlink"
"AcadFind" "AcadEPlotExt" "AcadDwgAids" "AcadDOrder" "AcadDim" "AcadDC"
"AcadDbConnect" "AcadCvPs" "AcadBrowser" "AcadBlock" "AcadAttedit"
"AcadAppload" "AcadApp")
alanjt
  • Standby for witty remark...
« Reply #4 on: October 18, 2009, 12:50:58 PM »
"AutoPlayer2000"!!
I haven't thought about that program in forever. That thing was a life saver!
Dropbox
