Author Topic: Detect AutoCAD version  (Read 9340 times)
Daniel J. Ellis
« on: January 11, 2011, 08:55:39 AM »
I've been using R2011, which has a wonderful feature as part of its hatch routine to specify the layer the hatch's going to be inserted on.
This is great, until you have a routine that sets the current to where you want the hatch to go to and freezes off the random layer you had been hatching on!
I'm the only one in the office using R2011 (everyone else uses R2010) so I need a way to detect which version of AutoCAD is being run so I can do the appropriate thing with my hatch command!
Is this something that can be done with LISP?
dJE
dJE
Re: Detect AutoCAD version
« Reply #1 on: January 11, 2011, 09:04:09 AM »
http://en.wikipedia.org/wiki/.dwg
No info on 2011 yet.
There are many ways to do it.
Drawing version
http://www.theswamp.org/index.php?topic=6774.msg333989#msg333989
ACAD version
((= (rtos(atof(getvar "ACADVER"))2 2) "15.00") 2000))
 ((= (rtos(atof(getvar "ACADVER"))2 2) "15.05") 2000i))
 ((= (rtos(atof(getvar "ACADVER"))2 2) "15.06") 2002))
 ((= (rtos(atof(getvar "ACADVER"))2 2) "16.00") 2004))
 ((= (rtos(atof(getvar "ACADVER"))2 2) "16.10") 2005))
 ((= (rtos(atof(getvar "ACADVER"))2 2) "16.20") 2006))
 ((= (rtos(atof(getvar "ACADVER"))2 2) "17.00") 2007)) ; 7 8 9
 ((= (rtos(atof(getvar "ACADVER"))2 2) "18.00") 2010))
VVA
« Reply #2 on: January 11, 2011, 09:15:49 AM »
(defun whatAcadVer ( / Aver)
(setq Aver (atof (substr (getvar "ACADVER") 1 4)))
((= Aver 18.0) 2010)
((= Aver 17.2) 2009)
((= Aver 17.1) 2008)
((= Aver 17.0) 2007)
((= Aver 16.2) 2006)
((= Aver 16.1) 2005)
((= Aver 16.0) 2004)
((= Aver 15.06) 2002)
(t 2011)
alanjt
  • Standby for witty remark...
« Reply #3 on: January 11, 2011, 09:31:32 AM »
(defun Version? (/)
  (cdr (assoc (atof (substr (getvar 'ACADVER) 1 4))
              '((18.1 . 2011)
                (18.0 . 2010)
                (17.2 . 2009)
                (17.1 . 2008)
                (17.0 . 2007)
                (16.2 . 2006)
                (16.1 . 2005)
                (16.0 . 2004)
                (15.06 . 2002)
Dropbox
yarik
« Reply #4 on: January 11, 2011, 11:30:45 AM »
Hi, maybe this can help
(defun acadvers()
(setq acad(atof(vlax-get-property (vlax-get-acad-object) 'version)))
(if (= acad 18.1)
(setq vers "ACAD2011")
(if (= acad 18.0)
(setq vers "ACAD2010")
vers
« Reply #5 on: January 11, 2011, 12:55:20 PM »
Another approach ... although I'm sure it can be broken  :-D
(defun getacadversion (/ path)
  (if (setq path (findfile "acad.exe"))
    (apply
      'strcat
      (mapcar 'chr (vl-remove-if-not '(lambda (x) (and (> x 47) (< x 58))) (vl-string->list path)))
(getacadversion)
;;Returns "2009"
alanjt
« Reply #6 on: January 11, 2011, 01:20:50 PM »
    (apply
      'strcat
(getacadversion)
;;Returns "2009"
Command: (findfile "acad.exe")
"C:\\Program Files\\Autodesk\\AutoCAD Civil 3D 2011\\acad.exe"
Returns: "32011"
Very cool idea. Way to think outside the box.
Dropbox
« Reply #7 on: January 11, 2011, 03:15:36 PM »
    (apply
      'strcat
(getacadversion)
;;Returns "2009"
Returns: "32011"
:) Thanks Alan ... perhaps this will fix it:
  (and (setq path (findfile "acad.exe"))
       (setq path (vl-remove-if-not '(lambda (x) (and (> x 47) (< x 58))) (vl-string->list path)))
       (setq path (apply 'strcat (mapcar 'chr path)))
       (setq path (substr path (- (1+ (strlen path)) 4)))
  path
(getacadversion)
alanjt
« Reply #8 on: January 11, 2011, 03:34:41 PM »
    (apply
      'strcat
(getacadversion)
;;Returns "2009"
Returns: "32011"
  path
(getacadversion)
Slight variant...
    ((lambda (str) (substr str (- (1+ (strlen str)) 4)))
      (vl-list->string
        (vl-remove-if-not (function (lambda (x) (and (> x 47) (< x 58)))) (vl-string->list path))
Dropbox
Chris
« Reply #9 on: January 11, 2011, 03:34:55 PM »
personally I prefer this:
(atoi (vl-string-right-trim " (en)" (vl-string-left-trim "Visual LISP " (ver))))
Christopher T. Cowgill, P.E.
AEC Collection 2020 (C3D)
Win 10
alanjt
« Reply #10 on: January 11, 2011, 03:41:52 PM »
(defun getacadversion (/)
  (vl-list->string
    (vl-remove-if-not (function (lambda (x) (and (> x 47) (< x 58)))) (vl-string->list (ver)))
Dropbox
« Reply #11 on: January 11, 2011, 03:44:52 PM »
 :ugly:
(defun version nil
  (cdr
    (assoc
      (atof
          (lambda ( key )
            (substr
              (setq key
                (substr key 1
                  (vl-string-position 92 key nil t)
              (+ 3 (vl-string-position 92 key nil t))
          (vlax-product-key)
        (18.1  . 2011)
        (18.0  . 2010)
        (17.2  . 2009)
        (17.1  . 2008)
        (17.0  . 2007)
        (16.2  . 2006)
        (16.1  . 2005)
        (16.0  . 2004)
        (15.06 . 2002)
alanjt
« Reply #12 on: January 11, 2011, 03:47:14 PM »
:ugly:
(defun version nil
  (cdr
    (assoc
      (atof
          (lambda ( key )
            (substr
              (setq key
                (substr key 1
          (vlax-product-key)
        (18.1  . 2011)
        (18.0  . 2010)
        (17.2  . 2009)
        (17.1  . 2008)
        (17.0  . 2007)
        (16.2  . 2006)
        (16.1  . 2005)
        (16.0  . 2004)
        (15.06 . 2002)
LoL, I think I'll stick with (getvar 'ACADVER).  :lol: Nice work either way.
Dropbox
« Reply #13 on: January 11, 2011, 03:54:44 PM »
 :-D  Me too  :-)
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #14 on: January 11, 2011, 04:07:19 PM »
my version
(atoi (substr (ver) 13))
