Code Red => AutoLISP (Vanilla / Visual) => Topic started by: Water Bear on February 24, 2004, 03:24:18 PM
Thanks to the good folks here at The Swamp I've worked up this duct calculator which makes conversions based on volume (cfm), velocity (fpm) and conversts to and from round ducts...it still needs some work to make it "pretty" but I've gone about as far as I know how...anyway I'll post it for input (I couldn't get it to calculate friction loss/100' duct) if anyone has suggestions please post, and if you can use it you're welcome to...thanx
(defun duct_calc (/)
;;; volume pressure velocity
;;; diam rey_no fric_fac width
;;; depth square friction area_sqft
(setq diam (getreal "\nEnter duct diameter:")
width (getreal "\nEnter duct width:")
depth (getreal "\nEnter duct depth:")
volume (getreal "\nEnter total CFM'S:")
velocity (getreal "\nEnter Velocity in FPM:")
((and diam volume)
(setq area_sqft (/ (* 0.7854 (expt diam 2.0)) 144.0)
width (* diam 0.914774703)
depth (* diam 0.914774703)
velocity (/ volume area_sqft)
pressure (expt (/ velocity 4005.00) 2)
(find_fric)
((and diam velocity)
volume (* area_sqft velocity)
(find_fric)
((and width depth volume)
(setq area_sqft (* (/ (* width depth) 144.0) 0.914774703)
square (sqrt (* area_sqft 144.0))
diam (* 1.3
(exp
(/ (log (/ (expt (* square square) 5.0)
(expt (+ square square) 2.0)
8.0
(find_fric)
((and width depth velocity)
diam (* 1.3
(exp
8.0
(find_fric)
((and volume velocity)
(setq area_sqft (/ (/ volume velocity) 0.914774703)
diam (* 1.3
(exp
8.0
(find_fric)
(t
((if volume
t
(prompt
"\nYou must enter diameter or Width x Depth or FPM..."
((if velocity
t
(prompt
"\nYou must enter a diameter or Width x Depth or CFM..."
(t
(prompt "\nYou must indicate CFMs or FPM..")
(defun find_fric ()
(setq rey_no (* 0.075 diam velocity (/ 1.0 0.0432))
;<=need coefficient for viscosity of standard air in pounds/ft hr
fric_fac (/ 64.0 rey_no) ;<=only good if reynolds is less than 2000
friction (* fric_fac (/ 1200 diam) pressure)
) ;<==Darcy/Weisbach
:D
Cool. (I work in the mech field too.) Ill help help as much as i can when i get spare time. (I work in Microstation alot now, but i do still use Acad once and a while so this would be cool.)
Excellent job there water bear
Thanks for the kind words Mark. I, in turn, must thank CAB, and DParcon for their help... :D
Looks really great, Water Bear.
The factor 0.914774703, is that a workaround for not isolating one of the square sides in the formula that was discussed in the "you say you're pretty good at numbers...." thread?
Man, I gave up on that formula.
Yes, SMadsen, that's the one that had me pulling my hair out! lol
Great job...
Some superficial stuff that is a personal preference.
You can create local functions to make the code more readable
and it localizes formula. So if you need to change a formula
it is in one place not many copies.
I added some window dressing and did a little filter on the inputs.
I'm still on the lower end of programing prowess so consider the
source.
;;; Duct calc returns the friction value
;;; Local Functions
;; given the area in square feet returns the diameter
(defun area2dia (sf_area / square)
(setq square (sqrt (* sf_area 144.0)))
(* 1.3
(exp
8.0
) ; end defun
;; given diameter returns the side dimension
(defun dia2sq (dia)
(* dia 0.914774703)
;; given the diameter returns the area in sq ft
(defun dia2area (dia)
(/ (* 0.7854 (expt dia 2.0)) 144.0)
;; given the sides returns the area in sq ft
(defun rec2area (w d) ; retangle to area
(* (/ (* w d) 144.0) 0.914774703)
(defun veloc2press (vel)
(expt (/ vel 4005.00) 2)
;; calc friction
(defun find_fric ()
;;; Start of Routine
(prompt "\nEnter known values. Press Enter if not known. ")
(setq diam (getreal "\nEnter duct diameter: "))
(if (null diam) ; skip if diameter entered
(setq width (getreal "\nEnter duct width: ")
depth (getreal "\nEnter duct depth: ")
(setq volume (getreal "\nEnter total CFM'S: ")
velocity (getreal "\nEnter Velocity in FPM: ")
;; Process user input
((and diam volume)
(setq area_sqft (dia2area diam)
width (dia2sq diam)
depth width
pressure (veloc2press velocity)
(find_fric)
width (dia2sq diam)
depth width
(find_fric)
(setq area_sqft (rec2area width depth)
diam (area2dia area_sqft)
(find_fric)
(find_fric)
width (dia2sq diam)
depth width
(find_fric)
(t (alert "\nInsufficient data retry inputs..."))
) ; end cond stmt
) ; end defun
Nice mop-up! Looks much cleaner! what do you think about a prompt for additional info, I had added this
(t
((if volume
t
(prompt
((if velocity
t
(prompt
(t
instead of that last condition? and can we get it to switch to (textscr) and list all variables..
How about this?
(t
((or volume velocity)
(prompt
(t
(defun c:test (/ friction)
(while (null (setq friction (duct_calc))))
(print friction)
Looks really good CAB putting it all together...how about something like this at the end:
;;; Local Functions
(* 1.3
(exp
8.0
) ; end defun
(defun dia2sq (dia)
(* dia 0.914774703)
;; calc friction
(defun find_fric ()
;; Process character pressed
((and diam volume)
width (dia2sq diam)
depth width
(find_fric)
width (dia2sq diam)
depth width
(find_fric)
(find_fric)
(find_fric)
width (dia2sq diam)
depth width
(find_fric)
(t
(prompt
"\nYou must enter diameter or Width x Depth..."
(t
) ; end cond stmt
(textscr)
(mapcar 'print
(list diam volume width depth velocity friction)
Ok, add some more input filter and revised you print function.
(defun duct_calc (/ friction volume pressure
velocity diam rey_no fric_fac
width depth area_sqft
;;; Local Functions
(* 1.3
(exp
8.0
) ; end defun
(defun dia2sq (dia)
(* dia 0.914774703)
;; calc friction
(defun find_fric ()
;; Get User Input
(setq volume (getreal "\nEnter total CFM'S: "))
(if (null (and (or diam (and width depth)) volume))
(setq velocity (getreal "\nEnter Velocity in FPM: "))
;; Process User Input
((and diam volume)
width (dia2sq diam)
depth width
(find_fric)
width (dia2sq diam)
depth width
(find_fric)
(find_fric)
(find_fric)
width (dia2sq diam)
depth width
(find_fric)
(t
(prompt
(t
) ; end cond stmt
(textscr)
(mapcar '(lambda (x) (prompt (strcat "\n" (car x) (rtos (cdr x) 2))))
(list (cons "Diameter " diam)
(cons "Width " width)
(cons "Depth " depth)
(cons "Volume " volume)
(cons "Velocity " velocity)
(cons "Friction " friction)
) ; end defun
(print friction)
Man! you aregood! And you've only been doing this for 3 months? :shock:
Now if I could only figure out the @#$% friction factor! The problem there is that they use Colebrook's equation which "...cannot be explictly solved for the friction factor, so you must use iterative techniques. :twisted:
Thanks.
No, more like a year. 8)
Gettin started is the hard part.
CAB, take a look at this one and give me your thoughts:
(http://theswamp.org/lilly.pond/Water%20Bear/colebrook%20copy.jpg)
This is supposed to replace the formula I have for "fric_fac"
That math is over my head :(
Is that the formula they talk about here?
Note: Friction losses have been calculated based on the Darcy equation.
The friction factor was determined by using a simplified formula by
Altshule/Tsal (see ASHRAE, 1997 Fundamentals, Chapter 32). The absolute
roughness factor of 0.0003 ft for the medium smooth roughness category
galvanized steel ductwork is used in the calculation.
One another subject,
Have you run across any software you would recommend for calculating and print a
Manual J form. Hillsborough County requires it for permit & although I use the
Energy Gauge software it doesn't print the Manual J.
No I haven't seen any, but I'll ask around the office.
Is there a formula with that excerpt?
The one I've got is from 1977 chapter 31 ! :roll: And they reference a computer algorthim which I have not been able to find:
H.F. Behls:Computerized Calculation of duct friction (U.S. Bureau of standards, Building Science Series 39, October 1971, p. 363
Here are a few links that may be of interest.
So, the formula f=64/R for laminar flow is no good?
Ducts are too rough?
http://www.hvac-toolbox.com/37_444.html
http://www.hvac-toolbox.com/37_459.html
http://www.efunda.com/formulae/fluids/calc_pipe_friction.cfm#friction
http://www.edasolutions.com/Groups/Tech/Calculations.htm
Good find CAB! that 37_444.html had the perfect equation...I did away with that Reynolds no. & Darcey equations (too theoretical!)
This one works just fine Pd = (0.109136 x q^1.9)/ d^5.02
Got a couple of hiccups though
*it computes the friction value correctly, but it does not display it correctly
*and the other is that if you enter a diameter and volume it computes everything properly, but if you use the square duct size you just got and the same volume , there is a discrepancy in the velocity--I think it has something to do with the computation of the area_sqft (there is a .91 difference when u convert back and forth from round to square)
*I could probably get rid of the pressure calc, it was needed for Reynold's
(defun duct_calc (/) ; friction volume pressure
;;; velocity diam rey_no fric_fac
;;; width depth area_sqft
;;; Local Functions
(* 1.3
(exp
8.0
) ; end defun
(defun dia2sq (dia)
(* dia 0.914774703)
;;(* (/ (* w d) 144.0) 0.914774703);<=changed
(/ (* w d) 144.0)
;; calc friction
(defun find_fric ()
(setq friction (/ (* 0.109136 (expt volume 1.9)) (expt diam 5.02)))
;; Get User Input
((and diam volume)
width (dia2sq diam)
depth width
(find_fric)
width (dia2sq diam)
depth width
(find_fric)
velocity (/ volume area_sqft);<==try multiplying area_sqft(0.914774703)
(find_fric)
(find_fric)
width (dia2sq diam)
depth width
(find_fric)
(t
(prompt
"\nYou must enter diameter or Width x Depth ..."
(t
) ; end cond stmt
(textscr)
(mapcar '(lambda (x) (prompt (strcat "\n" (car x) (rtos (cdr x) 2 3))))
) ; end defun
(print friction)
I corrected the friction display, although now it displays everything to 3 places :shock:
I revised the routine, bring the sledg hammer back.
Altered the (rtos (cdr x) 2 8)
to return 8 decimal points
Conversion from sq to rnd to sq works
Velocity is in error due to area formula.
the rnd duct area is ok for velocity but the sq area must be equevalent area.
This is what I came up with... :?
;;; Local Functions
;; returns the square side dimension equivelant of rnd duct
(defun rnd_to_sqr (dia ; dia of round duct
a ; side A of square duct
/ loop fuzz b)
(if (= (type a) 'int); make sure A is a REAL
(setq a (* a 1.0))
(setq b a ; B is target
fuzz 0.001
loop t
;; Returns Side B of square duct
(while loop
(setq dia2
(* 1.3
(exp (/ (log (/ (expt (* a b) 5) (expt (+ a b) 2))) 8))
(if (equal dia2 dia fuzz)
(setq loop nil) ; done
(setq b (* b (/ dia dia2)))
b
) ; end defun
(* 1.3
(exp
8.0
) ; end defun
(defun dia2sq (dia)
;;(* dia 0.914774703)
;;(*(sqrt area_sqft)12)
(setq depth (* (sqrt area_sqft) 12)) ; CAB
(rnd_to_sqr dia depth) ; CAB
;;; given the diameter returns the area in sq ft
;;(/ (* 0.7854 (expt dia 2.0)) 144.0)
(/ (* pi (expt (/ dia 2.0) 2.0)) 144.0) ; CAB
(/ (* w d) 144.0)
;; calc friction
(defun find_fric ()
;; Get User Input
((and diam volume)
width (dia2sq diam)
;;depth width
(find_fric)
width (dia2sq diam)
;;depth width
(find_fric)
;;velocity (/ volume area_sqft)dia2area
velocity (/ volume (dia2area diam))
(find_fric)
(find_fric)
width (dia2sq diam)
;;depth width
(find_fric)
(t
(prompt
(t
) ; end cond stmt
(textscr)
(mapcar '(lambda (x) (prompt (strcat "\n" (car x) (rtos (cdr x) 2 8))))
(cons "Area " area_sqft)
friction ; return flag, nil if failed
) ; end defun
(print friction)
Good one! ...and suppose that the only values we know are the volume and desired maximum friction?
;;; Local Functions
/ loop fuzz b)
(if (= (type a) 'int) ; make sure A is a REAL
(setq a (* a 1.0))
fuzz 0.001
loop t
(while loop
(setq dia2
(* 1.3
b
) ; end defun
(* 1.3
(exp
8.0
) ; end defun
(defun dia2sq (dia)
(/ (* w d) 144.0)
;; calc friction
(defun find_fric ()
;; Get User Input
friction (getreal "\nEnter FRICTION value: ")
((and friction volume)
(setq diam (exp
(/ (log (/ (* 0.109136 (expt volume 1.9)) friction)) 5.02)
width (dia2sq diam)
depth width
((and diam volume)
width (dia2sq diam)
;;depth width
(find_fric)
width (dia2sq diam)
;;depth width
(find_fric)
(find_fric)
(find_fric)
width (dia2sq diam)
;;depth width
(find_fric)
(t
(prompt
(t
) ; end cond stmt
(textscr)
) ; end defun
(print friction)
Cleaned it up a bit.
Adjusted the input filter logic.
;;; Local Functions
/ loop fuzz b)
(setq a (* a 1.0))
fuzz 0.001
loop t
(while loop
(setq dia2
(* 1.3
b
) ; end defun
(* 1.3
(exp
8.0
) ; end defun
(defun dia2sq (dia)
(/ (* w d) 144.0)
;; calc friction
(defun find_fric ()
;; Get User Input
(setq friction (getreal "\nEnter FRICTION value: "))
(if (null (and (or diam (and width depth)) volume friction))
(setq diam (exp
width (dia2sq diam)
((and diam volume)
width (dia2sq diam)
friction (find_fric)
width (dia2sq diam)
width (dia2sq diam)
(t
(prompt
(t
) ; end cond stmt
(textscr)
) ; end defun
(print friction)
Excellent stuff CAB! Now I've got something usable! The only thing I think I need is to make it loop while trying different square size combinations. Thanx, I really appreciate all your help... :D
Any time...
Changed the print function to allow nil in case you pressed Enter to all prompts.
This TEST routine will loop until Escape or Enter to all.
;;; Local Functions
/ loop fuzz b)
(setq a (* a 1.0))
fuzz 0.001
loop t
(while loop
(setq dia2
(* 1.3
b
) ; end defun
(* 1.3
(exp
8.0
) ; end defun
(defun dia2sq (dia)
(/ (* w d) 144.0)
;; calc friction
(defun find_fric ()
;; Get User Input
(setq diam (exp
width (dia2sq diam)
((and diam volume)
width (dia2sq diam)
width (dia2sq diam)
width (dia2sq diam)
(t
(prompt
(t
) ; end cond stmt
(textscr)
(car x)
(if (cdr x)
(rtos (cdr x) 2 8)
"X"
) ; end defun
(while (setq friction (duct_calc)))
(print friction)
added for known diameter and friction, compute volume, velocity and square
;;; Local Functions
/ loop fuzz b)
(setq a (* a 1.0))
fuzz 0.001
loop t
(while loop
(setq dia2
(* 1.3
b
) ; end defun
(* 1.3
(exp
8.0
) ; end defun
(defun dia2sq (dia)
(/ (* w d) 144.0)
;; calc friction
(defun find_fric ()
;; Get User Input
((and friction diam)
(setq volume (exp
(/ (log (/ (* friction (expt diam 5.02)) 0.109136)) 1.9)
width (dia2sq diam)
(setq diam (exp
width (dia2sq diam)
((and diam volume)
width (dia2sq diam)
width (dia2sq diam)
width (dia2sq diam)
(t
(prompt
(t
) ; end cond stmt
(textscr)
(car x)
(if (cdr x)
(rtos (cdr x) 2 8)
"X"
) ; end defun
(print friction)
Did I cover all possibilities?
All you need now is a DCL version. :D
Hi all you, you did a very good program in only two days. :lol: :D
As a user of ductwork normally the duct are rectangular and often one side is keep constant , just as a matter to suit the space in the ceiling.
Guess you have a free space of 2' the constant side must be less than 2'
to allow the isolation and frame space.
Of course that when the side ratio is to big the constant side shall be changed.
Thanks againg..
Whaaa! :shock: :shock:
Water Bear, please apologize me.
I just try to express a wish as a user of duct work.
Normally I used a duct calculator rule , the same it had been used since 40 years or more back from now.
This rule work on the same friction loos expresed on inch of water column by 100 ft
Usually a fixed valued is used as per economic reazon and the allowable presure to be suited by the fan.
A normal value is set from 0.1 to 0.25 inch water column by 100'
This system allow an easy way to know the total pressure loos of a system.
Hope you understand me , my english is poor , because I'm not in USA and it is my second language.
:oops: :oops:
OK..I found inconsistencies when square duct sizes were input..corrected that new:
(defun duct_calc
(/ friction volume velocity diam width depth area_sqft)
;;; Local Functions
/ loop fuzz b)
(setq a (* a 1.0))
fuzz 0.001
loop t
(while loop
(setq dia2
(* 1.3
b
) ; end defun
(* 1.3
(exp
8.0
) ; end defun
(defun dia2sq (dia)
;;given a square duct, make it round<=====added this
(defun make_round (w d)
(* 1.3
(exp
(/ (log (/ (expt (* w d) 5.0)
(expt (+ w d) 2.0)
8.0
;; calc friction
(defun find_fric ()
;; Get User Input
(setq volume (exp
width (dia2sq diam)
(setq diam (exp
width (dia2sq diam)
((and diam volume)
width (dia2sq diam)
width (dia2sq diam)
((and width depth friction)
(setq diam (make_round width depth)
volume (exp
1.9
volume (* (dia2area diam) velocity)
width (dia2sq diam)
(t
(prompt
(t
) ; end cond stmt
(textscr)
(car x)
(if (cdr x)
(rtos (cdr x) 2 2)
"X"
;friction ; return flag, nil if failed
) ; end defun
(print friction)
