Author Topic: Tool Palettes  (Read 12085 times)
Glenn R
Tool Palettes
« on: February 08, 2006, 09:26:35 PM »
Has anybody done anything to programatically access these little beasties? I'm not talking about creating a custom palette - there seems to be plenty of information for that.
What I'm talking about is iterating the currently loaded palettes and doing stuff ie. Loading/unloading, visible/not visible etc.
Any thoughts anyone?
Cheers,
Glenn.
Re: Tool Palettes
« Reply #1 on: February 08, 2006, 09:52:13 PM »
I'm blissfully ignorant Glenn ...    :wink:
Re: Tool Palettes
« Reply #2 on: February 08, 2006, 09:59:53 PM »
As you create them, can you create an array (like a control array) of ref's to them for iteration?? There must be some type of handle to keep track of to have access to them you would think.
- John Carmack
- J.R.R. Tolkien
Glenn R
Re: Tool Palettes
« Reply #3 on: February 08, 2006, 10:27:03 PM »
I'm not creating them as I mentioned. These are ones that are laoded into AutoCAD, either the standard example ones or the custom ones that I have.
It's difficult deciphering the docs...as we all know....:(
So far:
// get apointer to the editor
Editor ed = acadApp.DocumentManager.MdiActiveDocument.Editor;
// Get apointer to the tool palettes manager...
ToolPaletteManager tpMan = ToolPaletteManager.Manager;
// Get the tool pcatalog paths
ed.WriteMessage("\nCatalog path: {0}\n\n", tpMan.CatalogPath);
// get the cdollection of tool catalogs loaded
CatalogItemCollection catalogItems = tpMan.Catalogs;
tpMan.LoadCatalogs();
foreach(CatalogItem catalogItem in catalogItems) {
ed.WriteMessage("\n\nCatalog item type: {0}", CatalogItem.GetType(catalogItem.LocalFile).ToString());
if (!catalogItem.HasChildren)
continue;
for (int i = 0; i < catalogItem.ChildCount; i++) {
CatalogItem paletteItem = catalogItem.GetChild(i);
ed.WriteMessage("\nChild item type: {0}", CatalogItem.GetType(paletteItem.LocalFile).ToString());
if (CatalogItem.GetType(paletteItem.Url.ToString()) == CatalogItemType.ItemPalette) {
ed.WriteMessage("\nGot a palette!");
ed.WriteMessage("\nPalette name: {0}", paletteItem.Name);
Re: Tool Palettes
« Reply #4 on: February 08, 2006, 10:52:53 PM »
Are you getting any feedback from that Glenn?
(I can't test here 'till tomorrow, have to reload 2006 :( )
- John Carmack
- J.R.R. Tolkien
Re: Tool Palettes
« Reply #5 on: February 08, 2006, 11:02:59 PM »
How about "Palette Sets" ?
The CAdUiPaletteSet class contains a set of one or more palette windows (CAdUiPalette objects), and supports the following palette style constants:
I think this may be what you're after as the TPM seems to be working with the xml data not the actual windows.
- John Carmack
- J.R.R. Tolkien
Glenn R
Re: Tool Palettes
« Reply #6 on: February 08, 2006, 11:06:04 PM »
Mick,
Not as yet.
LE,
If you're referring to the BoltUI etc. sample that ships with the ObjectARX SDK, again this is creating a CUSTOM toolpalette.
I just want to programmatically manipulate the existing palettes (load/unload etc).
Cheers,
Glenn.
LE
Re: Tool Palettes
« Reply #7 on: February 08, 2006, 11:08:23 PM »
LE,
Cheers,
Glenn.
Yep... it was about that one....
Glenn R
Re: Tool Palettes
« Reply #8 on: February 08, 2006, 11:09:42 PM »
Mick,
I would concur, however getting one/creating one seems to be the difficult part unless I've totally overlooked something..............
Re: Tool Palettes
« Reply #9 on: February 08, 2006, 11:26:49 PM »
<edit - removed useless comments!>
try again!
« Last Edit: February 09, 2006, 06:04:51 PM by MickD »
- John Carmack
- J.R.R. Tolkien
Re: Tool Palettes
« Reply #10 on: February 09, 2006, 06:07:34 PM »
I can see where you're heading with this now Glenn and you're right in there's little documentation! And it's littered with COM and all sorts of nasty stuff.
I was getting confused with the sample in the AU docs on creating a tool pallete from scratch which was more like a stand alone dockable window than a 'tool palette'.
I should have 2006 loaded back on after lunch and I'll have a play. Have you got any further?
- John Carmack
- J.R.R. Tolkien
Glenn R
Re: Tool Palettes
« Reply #11 on: February 09, 2006, 08:58:08 PM »
Mick,
No further joy to report I'm afraid. I have some suspicions, but I won't taint your thinking process with them, until you have a chance to play with your own ideas.
Cheers,
Glenn.
Re: Tool Palettes
« Reply #12 on: February 09, 2006, 09:23:36 PM »
It works at my end Glenn, I pretty much just copied and pasted your code in and added a using ...Windows.ToolPalette; directive at the top.
here's the output.
I built the SimpleTools demo as well and it showed up in the list, will have to have a go at doing it with C#
- John Carmack
- J.R.R. Tolkien
Glenn R
Re: Tool Palettes
« Reply #13 on: February 09, 2006, 10:37:19 PM »
Mick,
I'm well aware that it works (I wrote it ;) )...it's just a starting point.
I want to be able to switch to another palette, hide tabs, load/unload activate a tab etc....this is the problem. I can't see where to go from there...if that makes sense.
Keep playing if you can...maybe I've missed something blatantly obvious to someone else.
Cheers,
Glenn.
Re: Tool Palettes
« Reply #14 on: February 12, 2006, 07:28:52 PM »
Glenn, I s'pose you've seen this :
anyway, others may not have, so ...
namespace Autodesk.AutoCAD.Windows.ToolPalette
     //// stripped by kwb 'cause  'The message exceeds the maximum allowed length (20000 characters). '
