Author Topic: (Challenge) Create a circle around text  (Read 7051 times)
« on: March 23, 2005, 08:07:50 AM »
Create a circle at the insertion point of each TEXT entity in a selection set, the circle will be 6% of the text height. Filter the selection so that it only contains TEXT with a "middle center" justification.
Possible pseudo code;
prompt user to create selection set
iterate through selection set creating a circle at each insertion point.
There is no time limit, let's see what you have. Bonus points for creativity.
Jimmy D
« Reply #1 on: March 23, 2005, 08:52:10 AM »
Would this do?
(defun c:TxtCircle (/ ss1 Count CrclRad CrclPnt Oldosmode OldEcho)
(setq Count 0
      Oldosmode (getvar "OSMODE")
      OldEcho (getvar "CMDECHO"))
(setvar "OSMODE" 0)
(setvar "CMDECHO" 0)
(setq ss1 (ssget "X" '((0 . "TEXT")(72 . 1)(73 . 2))))
(if (/= ss1 nil)(progn
(while (< Count (sslength ss1))
(setq CrclRad (* (cdr (assoc 40 (entget (ssname ss1 count)))) 0.06))
(setq CrclPnt (cdr (assoc 11 (entget (ssname ss1 count)))))
(command "._Circle" CrclPnt CrclRad)
(setq Count (+ Count 1))
(setvar "OSMODE" OldOsmode)
(setvar "CMDECHO" OldEcho)
BTW: NO copyright on this code!  :D
« Reply #2 on: March 23, 2005, 09:15:15 AM »
- Jimmy D
Second post here @theswamp and it's to a challange!! You're well on your way to becoming a regular here *grin*
Would this do?
Yep. Only I would let the user select the entities, but that's minor.
You might also want to use the bbcode tag "code". Here's how;
click on the button "Code", then paste/type in your text, then hit the button again. See also "First things first".
Jimmy D
« Reply #3 on: March 23, 2005, 09:25:19 AM »
Sorry about the "code" thing Mark.  :oops:
This is the corrected code:
  (setq Count     0
  (setvar "OSMODE" 0)
  (princ "\nSelect text objects... ")
  (setq ss1 (ssget '((0 . "TEXT") (72 . 1) (73 . 2))))
  (if (/= ss1 nil)
Jimmy D
« Reply #4 on: March 23, 2005, 09:30:00 AM »
The preview was OK, I swear!!   :cry:
[/code]
« Reply #5 on: March 23, 2005, 09:42:45 AM »
Not a big deal, just helps when reading the code. What happened was you use the "code" tag in your response, as in "Sorry about the "code" thing" without a closing tag. Anyway....... I fixed for ya.
« Reply #6 on: March 23, 2005, 10:35:54 AM »
Jimmy
Nice one, very good work...
« Reply #7 on: March 23, 2005, 11:10:50 AM »
OK, here is my attempt.
(defun c:TxtC (/ ss elst)
  (prompt "\nSelect text objects... <exit> ")
  (and (setq ss (ssget '((0 . "TEXT") (72 . 1) (73 . 2))))
       (repeat (sslength ss)
         (setq elst (entget (ssname ss 0)))
         (entmake (list '(0 . "CIRCLE")
                        (cons 10 (cdr (assoc 11 elst)))
                        (cons 40 (* (cdr (assoc 40 elst)) 0.06))
         (ssdel (ssname ss 0) ss)
SMadsen
« Reply #8 on: March 23, 2005, 11:32:43 AM »
Just had to make ^that semi-recursive
(defun C:TXTC (/ makeCircle)
  (defun makeCircle (ss / el e)
    (and ss (> (sslength ss) 0)
         (setq el (entget (setq e (ssname ss 0))))
                        (cons 10 (cdr (assoc 11 el)))
                        (cons 40 (* (cdr (assoc 40 el)) 0.06)))
         (makeCircle (ssdel e ss))
  (command "UNDO" "Begin")
  (makeCircle (ssget '((0 . "TEXT") (72 . 1) (73 . 2))))
  (command "UNDO" "End")
sinc
« Reply #9 on: March 23, 2005, 12:07:06 PM »
Is it considered cheating if you use the Express Tools' TCIRCLE command?   :D
(Actually, that may be harder than some of the stuff already posted...  :lol: )
« Reply #10 on: March 23, 2005, 12:19:23 PM »
Mark didn't post any rules so I guess anything goes! :)
« Reply #11 on: March 23, 2005, 01:43:28 PM »
I took a simpler approach. :D
(defun c:cctxt (/
                 ; local functions
                 make-circle get-text-size get-ins-point
                 ; local varibles
                 ss cntr ent
  (defun make-circle (inst_pt radius)
    (entmake
      (list
        '(0 . "CIRCLE")
        (cons 10 inst_pt)
        (cons 40 radius)
  (defun get-text-size (ent)
    (cdr (assoc 40 (entget ent)))
  (defun get-ins-point (ent)
    (cdr (assoc 11 (entget ent)))
  ;; =============== main starts here =================
  (setq ss (ssget
               (-4 . "<and")
               (0 . "TEXT")
               (72 . 1) ; justification - center
               (73 . 2) ;                 middle
               (-4 . "and>")
  (if (and ss (> (sslength ss) 0))
      (setq cntr 0)
      (while (setq ent (ssname ss cntr))
             (make-circle
      (get-ins-point ent)
      (* (get-text-size ent) 1.06)
             (setq cntr (1+ cntr))
    ; else
    (alert "No text found!!")
made a slight revision concerning the radius size
revision 2, changed the IF statement (thanks CAB)
« Reply #12 on: March 23, 2005, 02:01:25 PM »
Very quick crud ...
(defun c:crud ( / foo main )
    (defun foo ( ename / data )
        (vl-catch-all-apply
           '(lambda ()
                (vla-addcircle
                    (vlax-ename->vla-object
                        (cdr
                            (assoc 330
                                (setq data (entget ename))
                    (vlax-3d-point
                        (cdr
                            (assoc 10 data)
                    (* 0.03
                        (cdr
                            (assoc 40 data)
    (defun main ( / ss i )
        (if (setq ss (ssget "x" '((0 . "text")(72 . 1)(73 . 2))))
                (foo (ssname ss (setq i (1- i))))
    (main)
« Reply #13 on: March 23, 2005, 02:34:27 PM »
You just keep writing that "crud", I'm starting to catch-on!! :D
t-bear
« Reply #14 on: March 23, 2005, 03:21:56 PM »
WOW!!!  Five very different routines, and all five (actually Jimmmy's two make six)  work "a treat"!  Nice, fellas!
