Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
dimension polyline with annotation text
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: dimension polyline with annotation text (Read 2568 times)
pedroantonio
Guest
on:
September 06, 2015, 12:27:13 PM »
Hi. I am trying to convert an old code to work with annotation text but i have some probles with the code.
can any one help ?
Code - Auto/Visual Lisp:
[Select]
defun
readableAngle
ang
setq
ang
rem
rem
ang
pi
2.0
pi pi
pi
2.0
if
pi
0.5
ang
pi
1.5
ang pi
ang
defun
c:linedimannot
e p ht scl len pt ang
setvar
"cmdecho"
0
COMMAND
"_layer"
"_m"
"_Diast"
"_c"
"93"
"_lw"
"0.30"
command
"-style"
"_diast"
"wgsimpl.shx"
"A"
"Y"
"N"
1.75
"1"
"0"
"n"
"n"
"n"
while
getvar
"cmdactive"
0
command
if
and
setq
e
entsel
\n
select line or polyline :"
setq
e
car
e
member
cdr
assoc
0
entget
e
"LINE"
"LWPOLYLINE"
"POLYLINE"
progn
setq
len
vlax-curve-getdistatparam
e
vlax-curve-getendparam
e
; Get the length of the line/pline to its end.
setq
pt
vlax-curve-getpointatdist
e
len
2.0
; Get the point at mid of line/pline.
if
setq
v
vlax-curve-getparamatpoint
e
vlax-curve-getclosestpointto
e pt
setq
ang
angle
0.0
0.0
0.0
vlax-curve-getfirstderiv
e v
; Get angle at midpoint.
setq
ang
angle
e
len
2.0
0.01
e
len
2.0
0.01
entmakex
list
0
"TEXT"
100
"AcDbEntity"
100
"AcDbText"
10
0.0
0.0
0.0
; The base insert point of the text (ignored when not left aligned).
cons
1
rtos
len
2
2
; The length converted to text.
cons
50
readableAngle ang
; Rotate the text to follow the line/pline.
7
"_diast"
; Text style.
40
1.75
71
0
72
1
cons
11
polar
pt
pi
2
readableAngle ang
; The insert point of the text when not left aligned.
73
2
princ
\n
try again"
princ
thanks
Last Edit: September 07, 2015, 05:03:37 AM by Topographer
Logged
roy_043
Water Moccasin
BricsCAD 18
Re: dimension polyline with annotation text
Reply #1 on:
September 07, 2015, 04:19:31 AM »
In line 39 of the code a closing parenthesis is missing.
Logged
pedroantonio
Guest
Reply #2 on:
September 07, 2015, 05:05:07 AM »
I update the code but still not working .Any ideas?
Logged
roy_043
Water Moccasin
BricsCAD 18
Reply #3 on:
September 07, 2015, 07:08:28 AM »
The signature of the polar function is:
Code:
[Select]
(polar pt ang dist)
You are not supplying dist.
Logged
roy_043
Water Moccasin
BricsCAD 18
Reply #4 on:
September 07, 2015, 07:32:46 AM »
To preempt your next question:
To create annotative text entities you will probably need to switch from the entmake Lisp function to the use of the -TEXT command.
Logged
pedroantonio
Guest
Reply #5 on:
September 07, 2015, 09:52:28 AM »
Hi
roy_043
i update the code but the still be not annotated.
An a second qustion. Before change the code i use this command
[Select]
setq
kl
0.001275
scl
; scl = scale kl = the insert text distance from the line
to calculate the insert text distance from the line. Is any option to imput in the code the most use annotate scales in order to calculate the insert distanse ?
[Select]
defun
readableAngle
ang
setq
ang
rem
rem
ang
pi
2.0
pi pi
pi
2.0
if
pi
0.5
ang
pi
1.5
ang pi
ang
defun
c:linedimannot
setvar
"cmdecho"
0
COMMAND
"_layer"
"_m"
"_Diast"
"_c"
"93"
"_lw"
"0.30"
command
"-style"
"_diast"
"wgsimpl.shx"
"A"
"Y"
"N"
1.75
"1"
"0"
"n"
"n"
"n"
while
getvar
"cmdactive"
0
command
if
and
setq
e
entsel
\n
setq
e
car
e
member
cdr
assoc
0
entget
e
"LINE"
"LWPOLYLINE"
"POLYLINE"
progn
setq
len
e
e
setq
pt
e
len
2.0
if
setq
v
e
e pt
setq
ang
angle
0.0
0.0
0.0
e v
setq
ang
angle
e
len
2.0
0.01
e
len
2.0
0.01
entmakex
list
0
"TEXT"
100
"AcDbEntity"
100
"AcDbText"
10
0.0
0.0
0.0
cons
1
rtos
len
2
2
cons
50
readableAngle ang
7
"_diast"
; Text style.
40
1.75
71
0
72
1
cons
11
polar
pt
pi
2
readableAngle ang
0.25
73
2
princ
\n
try again"
princ
Logged
roy_043
Water Moccasin
BricsCAD 18
Reply #6 on:
September 07, 2015, 03:49:51 PM »
I don't know a way to get the most frequently used annotative scales. It is possible to get a list of *all* scales that are defined in the drawing. But this would not be very useful for your purpose I think.
I would change the code to use the -TEXT command (as mentioned before) and change the justification of the text to bottom center.
[Select]
defun
ReadableAngle
ang
setq
ang
rem
rem
ang
pi
2.0
pi pi
pi
2.0
if
pi
0.5
ang
pi
1.5
ang pi
ang
defun
Rad_To_Dgr
rad
rad pi
180.0
; Note 1: Only works for the WCS.
; Note 2: The code assumes that AUNITS=0.
; Note 3: Perhaps reset textstyle and clayer?
defun
c:LineDimAnnot
ang en len pt par
setvar
'cmdecho
0
command
"_.-layer"
"_make"
"_Diast"
"_color"
93
"_lweight"
0.30
command
"_.-style"
"_Diast"
"txt.shx"
"_annotative"
"_yes"
"_no"
1.75
1.0
0.0
"_no"
"_no"
"_no"
if
and
setq
en
car
entsel
\n
Select line or polyline:"
member
cdr
assoc
0
entget
en
"LINE"
"LWPOLYLINE"
"POLYLINE"
progn
setq
len
en
en
setq
pt
en
len
2.0
if
setq
par
en
en pt
setq
ang
angle
0.0
0.0
0.0
en par
setq
ang
angle
pt
en
len
2.0
0.01
; When is this required?
command
"_.-text"
"_justify"
"_bc"
"_non"
pt
Rad_To_Dgr
ReadableAngle ang
rtos
len
2
2
setvar
'cmdecho
1
princ
Logged
pedroantonio
Guest
Reply #7 on:
September 08, 2015, 11:16:47 AM »
Hi
roy_043
I test your code and the annotation works but now i have text rotation problem. look the dwg file to see my template settings for units
Logged
roy_043
Water Moccasin
BricsCAD 18
Reply #8 on:
September 08, 2015, 02:08:44 PM »
[Select]
defun
ReadableAngle
ang
setq
ang
rem
rem
ang
pi
2.0
pi pi
pi
2.0
if
pi
0.5
ang
pi
1.5
ang pi
ang
; Convert radians to gradians.
defun
Rad_To_Grad
rad
rad pi
200.0
; Note 2: The code assumes that AUNITS=2. ANGBASE and ANGDIR may vary.
defun
c:LineDimAnnot
ang en len pt par
setvar
'cmdecho
0
command
"_.-layer"
"_make"
"_Diast"
"_color"
93
"_lweight"
0.30
command
"_.-style"
"_Diast"
"txt.shx"
"_annotative"
"_yes"
"_no"
1.75
1.0
0.0
"_no"
"_no"
"_no"
if
and
setq
en
car
entsel
\n
member
cdr
assoc
0
entget
en
"LINE"
"LWPOLYLINE"
"POLYLINE"
progn
setq
len
en
en
setq
pt
en
len
2.0
if
setq
par
en
en pt
setq
ang
angle
0.0
0.0
0.0
en par
setq
ang
angle
pt
en
len
2.0
0.01
setq
ang
Rad_To_Grad
if
zerop
getvar
'angdir
ReadableAngle ang
getvar
'angbase
command
"_.-text"
"_justify"
"_bc"
"_non"
pt ang
rtos
len
2
2
setvar
'cmdecho
1
princ
Logged
pedroantonio
Guest
Reply #9 on:
September 08, 2015, 05:47:03 PM »
Thank you
roy_043
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
