Code Red => .NET => Topic started by: josano on November 09, 2010, 06:55:18 AM
Friends,
Researched a number automatically scale and found nothing talking about.
I've attached a picture listed.
Is to get the points for quoting?
Has anyone read or seen anything regarding this matter.
Thank you in advance any help.
Hugs,
Josano
http://www.theswamp.org/index.php?topic=31861.msg386487#msg386487 (http://www.theswamp.org/index.php?topic=31861.msg386487#msg386487)? (thx to fixo)
Kaefer,
Thanks for the help.
I have a question about this subject.
For dimension lines as i proceed?
I would pick the insertion points of lines.
P1________________P2_____________P3___
|P4_|_
Save the clicked points and generate quota.
Hugs,
Josano
You will also need to determine if the dimension is Horizontal or Vertical or Aligned and the line location ..
... this can't be done simply from a predetermined set of points.
Dimensioning is simple once these parameters are determined :)
unfortunately for programming, they are usually best determined by a rational mind.
HOWEVER ;
If you're dimensioning parametric shapes where the configuration can be predetermined you may be joyfull.
