Author Topic: Function for test. Any help appreciated :)  (Read 1877 times)
kruuger
« on: October 04, 2012, 06:53:00 AM »
hi
i wrote small routine to display edit_box and ask user to enter specific data like: text, number, int or real.
for exmaple. code below required correct layer name, match pattern
(kr:DCL_StdEditBoxDialog
  (list 1
    (list
      (cons 1 "Need string")
      (cons 2 "Incorect layer")
      (cons 4 "Layer already exist")
      (cons 8 "Only spaces not allow")
      (cons 16 "Layer name do not match pattern")
    "" "LAYER" "??-??"
  "Layer" "New layer: (format ??-??)" 40 13 (list "&Ok" "&Cancel") T 5
another one ask for cabinet width (with range 0 < X < 30):
  (list 3
    (list
      (cons 2 "Number can't be a zero")
      (cons 16 "This is not a number")
      (cons 32 "Cabinet to small")
      (cons 64 "Cabinet to big")
    "24" 0 30 4
  "Cabinet" "Enter width:" 40 13 (list "&Ok" "&Cancel") T nil
could you guys make few test and see if all works fine? especially dialog with numbers. dialog should be LUNITS, LUPREC and DIMZIN independant if we specify additional info.
i think kr:DCL_StdEditBoxDialog argument should be clear. only more info about DATA.
DATA is a list of:
1. Code 0,1-string, 2-INT number, 3-REAL number
2. Bit - bit codes with errors what edit_box need to check
3. Val - default value displayed at dialog
4, 5, 6 - optional like table name, range for numbers, precision, output units. all should be discover in example at top of the code attached file.
any improvements also welcome.
thanks,
kruuger
kruuger
Re: Function for test. Any help appreciated :)
« Reply #1 on: October 06, 2012, 06:06:48 PM »
