Author Topic: Edit SECTIONVIEWSTYLE dictionary  (Read 682 times)
VGon
  • Mosquito
« on: December 06, 2022, 03:05:00 PM »
Hi
I would like to edit the way the section view is tagged. Currently it is tagged as Section B-B \n Scale 1:30. I would like it presented as B-B(1:30). Overwriting the view does not help because after a ViewUpdate the tag gets reset back to the default. So I have learnt that it needs to be done using LISP. Sadly this is stored somewhere in the dictionary and I have never worked with dictionaries before.
So here's hoping someone is able to help with this code. I am working on BricsCAD but I think it might be the same for AutoCAD Mechanical too.
Regards,
PKENEWELL
Re: Edit SECTIONVIEWSTYLE dictionary
« Reply #1 on: December 07, 2022, 01:14:57 PM »
I don't know what it is in BriycsCAD, but in AutoCAD Mechanical - Look in "Options" > "AM:Standards" > "Section View (in list)" > "<double click current Style>"
« Last Edit: December 07, 2022, 01:17:58 PM by PKENEWELL »
"When you are asked if you can do a job, tell 'em, 'Certainly I can!' Then get busy and find out how to do it." - Theodore Roosevelt
VGon
  • Mosquito
« Reply #2 on: December 08, 2022, 06:19:25 AM »
Thanks for the response. Interesting to note the label options are amiable in AutoCAD, they seem to be missing in BricsCAD
Any suggestion on how to do this programatically
