Author Topic: DWFs - Create separate file from Sheet Set using Page Setup Override?  (Read 3201 times)
Matt__W
  • I like my water diluted.
I'm not too familiar with DWFs - typically we use PLTs or PDFs.
Is there a way using a page setup override for a Sheet Set to tell it to create separate DWFs - one for each sheet?  Some sysvar somewhere?  I didn't see anything in the PC3 file and nothing jumped out at me in the options dialog box.
Autodesk Expert Elite
New Shooz
Re: DWFs - Create separate file from Sheet Set using Page Setup Override?
« Reply #1 on: December 04, 2008, 09:43:32 AM »
Look in the Publish Options section of the PUBLISH command
Matt__W
« Reply #2 on: December 04, 2008, 09:53:26 AM »
Thanks... I found the options dialog box in the Sheet Set Manager.
