Author Topic: Namespace question?  (Read 3166 times)
iradic
Namespace question?
« on: June 22, 2006, 08:44:16 AM »
Hi, my first post here...
When I compile AutoLisp (no VisualLisp) code into VLX does it have it's own namespace for functions and variables?
I started writing Lisp and realized that I have some equally named functions and variables in different LSP files so I thought about just compiling them .)
Didge
Re: Namespace question?
« Reply #1 on: June 22, 2006, 09:03:06 AM »
When compiling within the vlisual lisp editor select the "expert" mode and it'll give you the choice of namespaces, this option will also allow you to include text and dcl files within the "vlx".
Edit:  Oops nearly forgot, welcome to the swamp Iradic :-)
Think Slow......
« Reply #2 on: June 22, 2006, 10:22:39 AM »
Welcome to theswamp. :-)
If you make your variables "Private" there won't be a problem with uncompiled lisp.
iradic
« Reply #3 on: June 24, 2006, 08:06:52 AM »
The main problem is error handler routine - i used the same name for all of my lisp functions...
« Reply #4 on: June 24, 2006, 09:39:14 AM »
Look at this:
http://www.theswamp.org/index.php?topic=8604.0
Also get acquainted with the SEARCH
http://www.theswamp.org/index.php?action=search;advanced
Enter "error handler"  with the quotes! then un-check this  [ ]Check all
then check [ ] AutoLISP (Vanilla / Visual) and check [ ] Show your stuff
Hit the search button & you will have lots of routines to look at.
LE
« Reply #5 on: June 24, 2006, 10:55:23 AM »
Welcome;
Make a protected namespace VLX
While in the Make Application do the following:
1. New Application wizard
2. Expert
3. Location and vlx name
4. Click Separate Namespace
5. Select the lisps,fas or PRJ's
6. Select DCL's (if applies)
7. Leave that Standard
8. Build the application
Load the VLX file, and just verify if any of the functions are protected with:
Command: !MyFunctionName
To export or import values to your protected namespace use the VL-DOC-REF - VL-DOC-SET
And for the functions use: VL-DOC-EXPORT - VL-DOC-IMPORT
HTH
Slim©
  • The Dude Abides...
« Reply #6 on: June 24, 2006, 11:45:40 AM »
Welcome, iradic.
You have two of the best helping you. CAB & LE.
Enjoy theSwamp.
iradic
« Reply #7 on: June 24, 2006, 01:16:07 PM »
Thanks... though I already read about "error handler" that if I read another one I will go crazy :)
Like this one (not quite error handler related):
http://discussion.autodesk.com/thread.jspa?messageID=1112382
