Author Topic: Select a range of cells at OpenOffice Calc  (Read 1975 times)
Doctor_Che
« on: November 19, 2015, 03:59:38 AM »
How can I open/show the OpenOffice Calc window and select a range of cells by mouse?
Ihave an example for MS Excel, but it does not work for OO Calc.
(princ "\nDictionary is not found. Please type data area manualy")
            (vlax-put-property ExcelApp 'Visible :vlax-true) ;open Excel
            (getstring "\nselect data area in Excel and then press enter")
            (setq used_range (vlax-get-property ExcelApp 'Selection))
            (setq lst (vlax-safearray->list (vlax-variant-value (vlax-get-property used_range 'Value))))
            (setq WorkBook (vlax-get-property ExcelApp "ActiveWorkBook"))
I just try it.
Application aborted: ActiveX Server returned the error: unknown name: VISIBLE
Application aborted: ActiveX Server returned the error: unknown name: SELECTION
roy_043
  • BricsCAD 18
