Author Topic: ARX Wizard 2008 installation  (Read 2485 times)
« on: May 08, 2007, 10:04:09 PM »
I was installing the ArxWizard < ..\ObjectARX 2008\Utils\ObjARXWiz\ArxWizards.msi >
The Wiz' hadn't been installed previously because I have been using my own templates for initial project startup.
The SDK was installed onto my Drive F: which is a removable drive that I take to and from various offices, and also use at my home office.
During the running of ArxWizards.msi the installer told me that, to effect, "ArxWizards.msi could not be found".
A flash of insight had me copy the  \ObjectARX 2008\.. folder from F:\ to C:\
... sure enough, the Wizard loaded correctly. Apparently there may be some hard coded folders\Drives in the installer
[*Smack*]
Glenn R
Re: ARX Wizard 2008 installation
« Reply #1 on: May 08, 2007, 10:31:51 PM »
smack indeed. Thanks for that Kerry.
