This should work for you. As you pick each point it writes the info to a crt file. This can then be cut and pasted as you see fit.
(defun c:os-ref ()
(setq
c_blp (getvar "BLIPMODE")
c_col (getvar "CECOLOR")
c_lay (getvar "CLAYER")
c_cmd (getvar "CMDECHO")
c_til (getvar "TILEMODE")
c_osm (getvar "OSMODE")
c_dimzin (getvar "DIMZIN")
c_qaf (getvar "QAFLAGS")
(setvar "osmode" 37)
(initget 4 "1 2 5 10 20 50 100 200 500 1250 2500")
(setq dimsc (atoi (getkword "Enter drawing scale - (1 2 5 10 20 50 100 200 500 1250 2500)")))
(if (= (tblsearch "block" "ref_pt") nil)
(progn (entmake '((0 . "BLOCK")
(2 . "REF_PT")
(70 . 0)
(10 0.0 0.0 0.0)
(entmake '((0 . "CIRCLE")
(67 . 0)
(8 . "0")
(10 0.0 0.0 0.0)
(40 . 0.75)
(210 0.0 0.0 1.0)
(entmake '((0 . "LINE")
(67 . 0)
(8 . "0")
(10 0.0 0.0 0.0)
(11 0.53033 0.53033 0.0)
(210 0.0 0.0 1.0)
(67 . 0)
(8 . "0")
(10 0.0 0.0 0.0)
(11 -0.53033 0.53033 0.0)
(210 0.0 0.0 1.0)
(67 . 0)
(8 . "0")
(10 0.0 0.0 0.0)
(11 -0.53033 -0.53033 0.0)
(210 0.0 0.0 1.0)
(67 . 0)
(8 . "0")
(10 0.0 0.0 0.0)
(11 0.53033 -0.53033 0.0)
(210 0.0 0.0 1.0)
(entmake '((0 . "ENDBLK"))
(setq prefix (if (= (setq test2 (getstring 1 (strcat "Enter reference prefix (. for none)<" (if (/= prefix nil) prefix ".") "> :"))) ".") prefix test2))
(if (/= (and (tblsearch "layer" "A0COORDS") (ssget "X" '((0 . "TEXT") (8 . "A0COORDS")))) nil)
(setq
no_ent (ssget "X" '((0 . "TEXT") (8 . "A0COORDS")))
no_ent2 (sslength no_ent)
cnt (+ no_ent2 1)
cnt (if (= (setq test (getint (strcat "Start numbering from? <" (rtos cnt 2 0) "> :"))) nil) cnt test)
coord_fil (open (strcat (getvar "DWGPREFIX") (SUBSTR (GETVAR "DWGNAME") 1 (- (STRLEN (GETVAR "DWGNAME")) 3)) "crd") "a")
pt1 (getpoint "\nPick point: ")
x (nth 0 pt1)
y (nth 1 pt1)
(command "layer" "m" "A0COORDS" "c" "7" "" "")
(setq
cnt 1
coord_fil (open (strcat (getvar "DWGPREFIX") (SUBSTR (GETVAR "DWGNAME") 1 (- (STRLEN (GETVAR "DWGNAME")) 3)) "crd") "w")
x (nth 0 pt1)
y (nth 1 pt1)
(write-line (strcat (strcat prefix (rtos cnt 2 0)) ","(strcat (rtos (/ y 1000) 2 3) "N")","(strcat (rtos (/ x 1000) 2 3) "E")) coord_fil)
(close coord_fil)
(command "insert" "ref_pt" pt1 dimsc dimsc "0")
(command "text" "m" "none" (subst (+ (* 2.1 dimsc) (cadr pt1)) (nth 1 pt1) pt1) (* dimsc 2.0) "0" (strcat prefix (rtos cnt 2 0)))
(setq cnt (+ cnt 1))
(setq pt1 (getpoint "\nPick point: "))
(while (/= pt1 nil)
(setq
x (nth 0 pt1)
y (nth 1 pt1)
(write-line (strcat (strcat prefix (rtos cnt 2 0))","(strcat (rtos (/ y 1000) 2 3) "N")","(strcat (rtos (/ x 1000) 2 3) "E")) coord_fil)
(close coord_fil)
(command "-layer" "thaw" c_lay "on" c_lay "")
(setvar "CLAYER" c_lay)
(setvar "BLIPMODE" c_blp)
(setvar "CECOLOR" c_col)
(setvar "CMDECHO" c_cmd)
(setvar "TILEMODE" c_til)
(setvar "OSMODE" c_osm)
(setvar "DIMZIN" c_dimzin)
(setvar "QAFLAGS" c_qaf)
