Author Topic: Tip (removing spaces from numbers)  (Read 3083 times)
« on: August 09, 2004, 02:12:28 PM »
Most of you probably know this but............
remove all spaces from around a number and return just the number
(rtos (atof "  34.988     ") 2 3)
--> "34.988"
same thing for integers
(itoa (atoi "  34     "))
--> "34"
Ron Heigh
« Reply #1 on: August 09, 2004, 03:14:55 PM »
Nice tip Mark.
rude dog
« Reply #2 on: August 10, 2004, 04:31:14 AM »
hey...kinda cool..didnt know that :)
CADaver
« Reply #3 on: August 10, 2004, 07:20:31 AM »
Well, I'll be danged, I ain't gonna tell ya' how I have been doing it.
daron
« Reply #4 on: August 10, 2004, 07:52:58 AM »
The other way could be to use find with a space and replace it with nothing, but Mark's way is much safer, until you can't convert it into a number like: "    34a   ".
« Reply #5 on: August 10, 2004, 09:39:53 AM »
The other way is to use VL ..
 (VL-STRING-TRIM " " "    34.988     " )
 (VL-STRING-TRIM " " "  34           " )
The poor cat gets skinned yet again ..
SPDCad
« Reply #6 on: August 10, 2004, 11:44:54 AM »
Nice Tip Mark!
To think I wrote a lisp that would eliminate spaces and convert a string number to a real number.  Its a good thing my lisp works with other string characters besides spaces or else I would feel real bad.
AutoCAD 2010, w/ OpenDCL
visit: http://reachme.at/spd_designs
