Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
Code Red
.NET
Topic:
About AutoCAD 2013 "acedTrans "
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: About AutoCAD 2013 "acedTrans " (Read 3620 times)
huangc
Guest
on:
April 11, 2012, 09:43:23 PM »
Hello, everyone.
I found "acedTrans" in 2013 can not continue to use.
Code - C#:
[Select]
DllImport
"acad.exe"
, CallingConvention
CallingConvention
Cdecl
, EntryPoint
"acedTrans"
static
extern
int
acedTrans
double
point,
IntPtr fromRb,
IntPtr toRb,
int
disp,
double
result
Prompt I can not find acedTrans entry point
Logged
It's Alive!
Retired
Needs a day job
AKA Daniel
WWW
Re: About AutoCAD 2013 "acedTrans "
Reply #1 on:
April 11, 2012, 11:25:15 PM »
it may not be in acad.exe anymore, I think some stuff was moved out to one of the dlls... core.dll or something
Logged
https://github.com/CEXT-Dan/PyRx
https://pyarx.blogspot.com/
huangc
Guest
Reply #2 on:
April 19, 2012, 05:51:24 AM »
You are right, it has been removed
Logged
Mesozoic relic
Seagull
class keyThumper<T>:ILazy<T>
Reply #3 on:
April 19, 2012, 07:41:43 AM »
I don't have time to play, but acedTrans in in acCore.dll
http://www.theswamp.org/index.php?topic=41527.0
Logged
Print
Pages: [
1
Go Up
« previous
next »
Code Red
.NET
Topic:
