I am writing a routine that will merge multiple blocks into one single block. What I have so far works fairly well, except if attributes from multiple blocks have the same name, then the routine doesn't know which attribute is which once the block is merged.
I am wondering if anyone has any ideas of how to handle this?
Here is the code so far:
(defun c:MergeBlocks (/ SS Filter)
(setq Filter '((0 . "INSERT")))
(while (not SS)
(princ "\rSelect Blocks to Merge: ")
(setq SS (ssget Filter))
(CW:MergeBlocks SS)
(defun CW:MergeBlocks (SS / Count SS_Length SS_Copy SS_Exploded SS_Temp SS_Temp_Length Ent Count_Temp Obj InsPt Block_Name Block_Name_Count OLD_AttReq Attributes)
(vla-StartUndoMark (vla-get-activedocument (vlax-get-acad-object)))
;Supporting Functions
;; Get Attribute Values - Lee Mac
;; Returns an association list of attributes present in the supplied block.
;; blk - [vla] VLA Block Reference Object
;; Returns: [lst] Association list of ((<tag> . <value>) ... )
(defun LM:vl-getattributevalues ( blk )
(mapcar '(lambda ( att ) (cons (vla-get-tagstring att) (vla-get-textstring att))) (vlax-invoke blk 'getattributes))
;; Set Attribute Values - Lee Mac
;; Sets attributes with tags found in the association list to their associated values.
;; lst - [lst] Association list of ((<tag> . <value>) ... )
;; Returns: nil
(defun LM:vl-setattributevalues ( blk lst / itm )
(foreach att (vlax-invoke blk 'getattributes)
(if (setq itm (assoc (vla-get-tagstring att) lst))
(vla-put-textstring att (cdr itm))
;End Suppoprting Functions
(setq Count 0
SS_Length (sslength SS)
SS_Exploded (ssadd)
(while (< Count SS_Length)
(setq Ent (ssname SS Count)
Obj (vlax-ename->vla-object Ent)
(if Block_Name
(setq Block_Name (strcat Block_Name "_" (vla-get-effectivename Obj)))
(setq Block_Name (vla-get-effectivename Obj))
(if Attributes
(setq Attributes (append (LM:vl-getattributevalues Obj) Attributes))
(setq Attributes (LM:vl-getattributevalues Obj))
(if (not InsPt)
(setq InsPt (vlax-safearray->list (vlax-variant-value (vla-get-insertionpoint Obj))))
(command "._explode" Ent "")
(setq SS_Temp (ssget "_P")
Count_Temp 0
SS_Temp_Length (sslength SS_Temp)
(while (< Count_Temp SS_Temp_Length)
(ssadd (ssname SS_Temp Count_Temp) SS_Exploded)
(setq Count_Temp (+ Count_Temp 1))
(setq Count (+ Count 1))
(setq Block_Name_Count 1)
(while (tblsearch "BLOCK" Block_Name)
(setq Block_Name (strcat Block_Name (rtos Block_Name_Count 2 0))
Block_Name_Count (+ Block_Name_Count 1)
(if SS_Exploded
(command "._-block" Block_Name InsPt SS_Exploded "")
(setq OLD_AttReq (getvar "ATTREQ"))
(setvar "ATTREQ" 0)
(command "._-insert" Block_Name InsPt "" "" "")
(setvar "ATTREQ" OLD_AttReq)
(setq Ent (entlast)
(princ "\nWorks!")(princ "\n")(princ Attributes)(princ "\n")
(if Attributes
(LM:vl-setattributevalues Obj Attributes)
(vla-EndUndoMark (vla-get-activedocument (vlax-get-acad-object)))
