Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
Help: Modify Lisp Scale block only
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Help: Modify Lisp Scale block only (Read 1859 times)
miquan
Guest
on:
December 18, 2013, 06:12:38 PM »
Dear all,
I tried to modified this lisp.
This is used to sclae block only with a scale factor.
I tried to store scale factor (by STR value in my lisp) from last command, and use it in the next one. But I failed.
Could you possibly help me?
Thanks,
Miquan
Code - Auto/Visual Lisp:
[Select]
defun
c:sb
tapblock sodt index soblocksua
entdt tt diemchen tyle DAIHT DAIMOI
TEMP str
init
princ
\n
Scale Block Only!"
setq
tapblock
ssget
0
"INSERT"
temp
initget
"R C"
SETQ
temp
GETVAR
"USERR3"
IF
temp
0
PROGN
SETQ
STR
"1"
SETVAR
"USERR3"
1
SETQ
STR
RTOS
temp
temp
getreal
\n
Scale Factor <"
STR
IF
temp
NIL
SETQ
temp
GETVAR
"USERR3"
SETVAR
"USERR3"
temp
tyle
cond
temp
"R"
setq
daiht
getdist
\n
Current Length: "
daimoi
getdist
\n
New Length: "
tyle
daimoi daiht
temp
"C"
setq
tyle
getreal
\n
New Scale Factor: "
t temp
sodt
sslength
tapblock
index
0
soblocksua
0
repeat
sodt
setq
entdt
ssname
tapblock index
index
1+
index
tt
entget
entdt
diemchen
trans
cdr
assoc
10
tt
0
1
soblocksua
1+
soblocksua
luuos
setvar
"OSMODE"
0
command
".scale"
entdt
diemchen tyle
traos
princ
strcat
\n
Number of Modified Blocks: "
itoa
soblocksua
sssetfirst
nil
tapblock
done
Logged
Global Moderator
Seagull
Re: Help: Modify Lisp Scale block only
Reply #1 on:
December 18, 2013, 08:58:27 PM »
Untested but may get you closer to your goal.
[Select]
defun
c:sb
tapblock sodt i ename tt diemchen daiht daimoi sb_scale
;(init)
princ
\n
Scale Block Only!"
setq
tapblock
ssget
0
"INSERT"
if
zerop
setq
sb_scale
getvar
"USERR3"
progn
setq
sb_scale
1
setvar
"USERR3"
1
initget
"R C"
setq
ans
getreal
strcat
\n
Scale Factor <"
rtos
sb_scale
2
2
cond
ans
"R"
setq
daiht
getdist
\n
Current Length: "
daimoi
getdist
\n
New Length: "
sb_scale
daimoi daiht
ans
"C"
setq
sb_scale
getreal
\n
New Scale Factor: "
type
ans
'real
setq
sb_scale ans
setvar
"USERR3"
sb_scale
setq
i
1
while
setq
ename
ssname
tapblock
setq
i
1+
i
setq
tt
entget
ename
diemchen
trans
cdr
assoc
10
tt
0
1
;(luuos)
setvar
"OSMODE"
0
command
".scale"
ename
diemchen sb_scale
;(traos)
princ
strcat
\n
itoa
sslength
tapblock
sssetfirst
nil
tapblock
;(done)
Last Edit: December 19, 2013, 09:00:58 AM by CAB
Logged
miquan
Guest
Reply #2 on:
December 19, 2013, 12:51:24 AM »
Dear CAB,
Thanks for your reply, I tried but it's failed.
The error is "too many arguments"
I re-post here with my lisp and some sub function.
Please look at and give me some advices.
Thanks,
Miquan
[Select]
defun
c:sb
tapblock tt diemchen daiht daimoi ans sb_scale i
init
princ
\n
Scale Block Only!"
setq
tapblock
ssget
0
"INSERT"
if
zerop
setq
sb_scale
getvar
"USERR3"
progn
setq
sb_scale
1
setvar
"USERR3"
1
initget
"R C"
setq
ans
getreal
\n
Scale Factor <"
rtos
sb_scale
2
cond
null
ans
setq
ans sb_scale
ans
"R"
setq
daiht
getdist
\n
Current Length: "
daimoi
getdist
\n
New Length: "
sb_scale
daimoi daiht
ans
"C"
setq
sb_scale
getreal
\n
New Scale Factor: "
setvar
"USERR3"
sb_scale
setq
i
1
while
setq
ename
ssname
ss
setq
i
1+
i
setq
tt
entget
ename
diemchen
trans
cdr
assoc
10
tt
0
1
luuos
setvar
"OSMODE"
0
command
".scale"
ename
diemchen sb_scale
traos
princ
strcat
\n
itoa
sslength
tapblock
sssetfirst
nil
tapblock
done
defun
miquan_newerror
msg
if
and
msg
"Function cancelled"
msg
"quit / exit abort"
princ
strcat
\n
msg
done
defun
init
setq
miquan_CMD
getvar
"CMDECHO"
miquan_OLDERROR
*error*
*error*
miquan_newerror
setvar
"CMDECHO"
0
command
".undo"
"BE"
defun
done
command
".redraw"
command
".undo"
"E"
if
miquan_CMD
setvar
"CMDECHO"
miquan_CMD
if
miquan_OLDERROR
setq
*error*
miquan_OLDERROR
princ
defun
luuos
setq
miquan_OSMODE
getvar
"OSMODE"
miquan_AUTOSNAP
getvar
"AUTOSNAP"
defun
traos
if
miquan_OSMODE
setvar
"OSMODE"
miquan_OSMODE
if
miquan_AUTOSNAP
setvar
"AUTOSNAP"
miquan_AUTOSNAP
Logged
Global Moderator
Seagull
Reply #3 on:
December 19, 2013, 09:01:28 AM »
I updated the code in my post, try again.
Logged
miquan
Guest
Reply #4 on:
December 20, 2013, 10:41:31 AM »
Dear CAB,
It works perfectly, Thanks so much.
Miquan
Logged
Global Moderator
Seagull
Reply #5 on:
December 20, 2013, 11:56:03 AM »
Glad to help.
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
