Author Topic: Plot MultiSheet PDF  (Read 1923 times)
JanetDavidson
  • Mosquito
Plot MultiSheet PDF
« on: October 10, 2016, 11:05:48 AM »
I need some Help here.
I am using  code below written by Gile  [  http://www.theswamp.org/index.php?topic=42265.0   ].
My question is why it doesn't work when :
 1 : drawing is unsaved or new .
 2: drawing is being opened as read only  by double clicking in an Email Attachment .
 3: And the last , AutoSave kicks in.
He is using database.filename which is correct but still I don't get it.
Thanks,
Janet.
using System.IO;
using System.Text;
using Autodesk.AutoCAD.PlottingServices;
using Autodesk.AutoCAD.Publishing;
using AcAp = Autodesk.AutoCAD.ApplicationServices.Application;
namespace Plottings
    public class MultiSheetsPdf
        private string dwgFile, pdfFile, dsdFile, outputDir;
        private int sheetNum;
        IEnumerable<Layout> layouts;
        private const string LOG = "publish.log";
        public MultiSheetsPdf(string pdfFile, IEnumerable<Layout> layouts)
            Database db = HostApplicationServices.WorkingDatabase;
            this.dwgFile = db.Filename;
            this.pdfFile = pdfFile;
            this.outputDir = Path.GetDirectoryName(this.pdfFile);
            this.dsdFile = Path.ChangeExtension(this.pdfFile, "dsd");
            this.layouts = layouts;
        public void Publish()
            if (TryCreateDSD())
                Publisher publisher = AcAp.Publisher;
                PlotProgressDialog plotDlg = new PlotProgressDialog(false, this.sheetNum, true);
                publisher.PublishDsd(this.dsdFile, plotDlg);
                plotDlg.Destroy();
                File.Delete(this.dsdFile);
        private bool TryCreateDSD()
            using (DsdData dsd = new DsdData())
            using (DsdEntryCollection dsdEntries = CreateDsdEntryCollection(this.layouts))
                if (dsdEntries == null || dsdEntries.Count <= 0) return false;
                if (!Directory.Exists(this.outputDir))
                    Directory.CreateDirectory(this.outputDir);
                this.sheetNum = dsdEntries.Count;
                dsd.SetDsdEntryCollection(dsdEntries);
                dsd.SetUnrecognizedData("PwdProtectPublishedDWF", "FALSE");
                dsd.SetUnrecognizedData("PromptForPwd", "FALSE");
                dsd.SheetType = SheetType.MultiDwf;
                dsd.NoOfCopies = 1;
                dsd.DestinationName = this.pdfFile;
                dsd.IsHomogeneous = false;
                dsd.LogFilePath = Path.Combine(this.outputDir, LOG);
                PostProcessDSD(dsd);
                return true;
        private DsdEntryCollection CreateDsdEntryCollection(IEnumerable<Layout> layouts)
            DsdEntryCollection entries = new DsdEntryCollection();
            foreach (Layout layout in layouts)
                DsdEntry dsdEntry = new DsdEntry();
                dsdEntry.DwgName = this.dwgFile;
                dsdEntry.Layout = layout.LayoutName;
                dsdEntry.Title = Path.GetFileNameWithoutExtension(this.dwgFile) + "-" + layout.LayoutName;
                dsdEntry.Nps = layout.TabOrder.ToString();
                entries.Add(dsdEntry);
            return entries;
        private void PostProcessDSD(DsdData dsd)
            string str, newStr;
            string tmpFile = Path.Combine(this.outputDir, "temp.dsd");
            dsd.WriteDsd(tmpFile);
            using (StreamReader reader = new StreamReader(tmpFile, Encoding.Default))
            using (StreamWriter writer = new StreamWriter(this.dsdFile, false, Encoding.Default))
                while (!reader.EndOfStream)
                    str = reader.ReadLine();
                    if (str.Contains("Has3DDWF"))
                        newStr = "Has3DDWF=0";
                    else if (str.Contains("OriginalSheetPath"))
                        newStr = "OriginalSheetPath=" + this.dwgFile;
                    else if (str.Contains("Type"))
                        newStr = "Type=6";
                    else if (str.Contains("OUT"))
                        newStr = "OUT=" + this.outputDir;
                    else if (str.Contains("IncludeLayer"))
                        newStr = "IncludeLayer=TRUE";
                    else if (str.Contains("PromptForDwfName"))
                        newStr = "PromptForDwfName=FALSE";
                    else if (str.Contains("LogFilePath"))
                        newStr = "LogFilePath=" + Path.Combine(this.outputDir, LOG);
                    else
                        newStr = str;
                    writer.WriteLine(newStr);
            File.Delete(tmpFile);
        [CommandMethod("PlotPdf")]
        public void PlotPdf()
            short bgp = (short)AcAp.GetSystemVariable("BACKGROUNDPLOT");
            try
                AcAp.SetSystemVariable("BACKGROUNDPLOT", 0);
                    List<Layout> layouts = new List<Layout>();
                    DBDictionary layoutDict =
                        (DBDictionary)db.LayoutDictionaryId.GetObject(OpenMode.ForRead);
                    foreach (DBDictionaryEntry entry in layoutDict)
                        if (entry.Key != "Model")
                            layouts.Add((Layout)tr.GetObject(entry.Value, OpenMode.ForRead));
                    layouts.Sort((l1, l2) => l1.TabOrder.CompareTo(l2.TabOrder));
                    string filename = Path.ChangeExtension(db.Filename, "pdf");
                    MultiSheetsPdf plotter = new MultiSheetsPdf(filename, layouts);
                    plotter.Publish();
                    tr.Commit();
            catch (System.Exception e)
                Editor ed = AcAp.DocumentManager.MdiActiveDocument.Editor;
                ed.WriteMessage("\nError: {0}\n{1}", e.Message, e.StackTrace);
            finally
                AcAp.SetSystemVariable("BACKGROUNDPLOT", bgp);
MexicanCustard
Re: Plot MultiSheet PDF
« Reply #1 on: October 11, 2016, 07:41:40 AM »
Database.Filename is referring to your .DWT template file.
Database.Filename is referring  to the temporary file created.
Database.Filename is referring to the temporary file created by autosave.  In this situation Document.Filename will give you the correct filename.
You can check for each situation using the system variable DWGTITLED.
