Author Topic: On App Activate Event  (Read 6575 times)
ML
Re: On App Activate Event
« Reply #30 on: October 18, 2007, 11:26:29 AM »
OK, well, here is my last attempt
The code works well but it still did not resolve the problem
DAM cui files!  :pissed:
The below code will check for your Active Profile,
Your current menu (main cui) file
Then set the workspace you want to be current.
Thanks again Matt!
Sub WsCurrent()
Dim Username As Variant
Dim Preferences As AcadPreferences
Dim ActProfile As String
Dim CurrMenuPath As String
Dim CurrMenuFile As String
Set WshNetwork = CreateObject("WScript.Network")
Set Preferences = ThisDrawing.Application.Preferences
Username = WshNetwork.Username
ActProfile = Preferences.Profiles.ActiveProfile
CurrMenuPath = "C:\Documents and Settings\" & Username & "\Application Data\Autodesk\Autodesk Land Desktop 2006\R16.2\enu\Support\"
CurrMenuFile = Preferences.Files.MenuFile
If ActProfile = "Land Desktop" Then
  Select Case CurrMenuFile
   Case Is = CurrMenuPath & "land"
   ThisDrawing.SetVariable "wscurrent", "Land Destop Complete"
  End Select
End If
If ActProfile = "MapGeneral" Then
   Case Is = CurrMenuPath & "acmap"
   ThisDrawing.SetVariable "wscurrent", "Map Classic"
  End Select
End If
Guest
« Reply #31 on: October 19, 2007, 05:54:04 PM »
It's NOT gonna work because you STILL haven't spelled it correctly!!!
 :wink: :-)
ML
« Reply #32 on: October 19, 2007, 05:55:15 PM »
LOL
Good catch! :)
ML
« Reply #33 on: October 19, 2007, 05:55:33 PM »
Have a great weekend man!
ML
« Reply #34 on: October 31, 2007, 10:49:29 AM »
OK, I definetely got it now and it is doing exactly what the article said
On startup, set the workspace that you want current to be current.
This fixed my toolbar location problem; they are now being retained on each start of ACAD.
I think my earlier approach to the coding was the reason it was not working.
If anyone is interested; here is my approach and code:
Again, for me, it is working just fine.
On Startup, in The acad.dvb file
Sub Acadstartup()
Set AutoCAD = ThisDrawing.Application
RunMacro ("WsCurrent")  '<----- This is calling my WsCurrent Module
WsCurrent Module:
Sub WsCurrent()
 CurrMenuFile = CurrMenuPath & "land"
End If
 CurrMenuFile = CurrMenuPath & "acmap"
End If
