Author Topic: The notification about attempt of opening newer dwg format than it can be opened  (Read 1720 times)
Andrey Bushman
Hi all,
How can I get the notification about attempt of opening newer dwg format than it can be opened in current AutoCAD?
I've searched the similar events in the DocumentCollection Events and Database Events of the ObjectARX SDK documentation but I found nothing...
Thank you.
BillZndl
Possibly helpful?
http://through-the-interface.typepad.com/through_the_interface/2006/08/breaking_it_dow.html
Quote from: Kean
"but how do I check a DWG's version before I read it in?" Luckily, the first 6 bytes of any DWG indicate its version number
Andrey Bushman
I have no problem with defining of DWG version. My question is about other theme.
BillZndl
I see.
I was thinking you'd have to test the file before attempting to open it.
MC0.0 - DWG from Rel. 1.1
AC1.2 - DWG from Rel. 1.2
AC1.4 - DWG from Rel. 1.4
AC1.50 - DWG from Rel. 2.0
AC2.10 - DWG from Rel. 2.10
AC1002 - DWG from Rel. 2.5
AC1003 - DWG from Rel. 2.6
AC1004 - DWG from Rel.9
AC1006 - DWG from Rel.10
AC1009 - DWG from Rel.11/12 (or LT R1/R2)
AC1012 - DWG from Rel.13 (or LT95)
AC1014 - DWG from Rel.14, 14.01 (or LT97/LT98)
AC1015 - DWG from AutoCAD 2000/2000i/2002 (or LT, Map or relative Desktop version)
AC1018 - DWG from AutoCAD 2004/2005/2006 (or other product in the "2004", "2005" or "2006" family)
AC1021 - DWG from AutoCAD 2007/2008/2009 (or other product of the "2007", "2008" and "2009" families)
AC1024 - DWG from AutoCAD 2010/2011/2012 (or other product of the "2010", "2011" and "2012" families)
AC1027 - DWG from AutoCAD 2013/2014/2015/2016/2017 (or other product of the "2013", "2014", "2015", "2016" and "2017" families)
Andrey Bushman
User can try to open DWG version newer than AutoCAD can open through Windows Explorer or OpenFile dialog. I want to be notified about it through an event.
roy_043
  • BricsCAD 18
Perhaps using a command reactor and checking for a 'command failed' event will work. In Lisp (I don't use the .NET API) this works in principle.
