And please explain, in short, how you would expect them to work. Thinking of maybe putting something together, and just want to see what others would like to see happen.
Thanks.
Edit: Attached version 0.1 of Xref Suite tools ( source and compiled dll file ). Once the dll is loaded, it will list what commands can be used, and a brief description of what they are for. Comments welcomed. I'm still working on some of the other ideas that are not in this release.
@Tracey - I'm still looking at how one would do a window selection of nested items.
@Crank - Still not sure how one would want to have the procedure for setting up relative paths work. I don't use them, so I had to look in the help, and it seems like they can be setup plenty of ways. Would someone just select the drawing(s) to edit the xref paths, and then have the paths based off that drawings path? Let me know what your thinking.
