Author Topic: Paper Space Objects  (Read 5415 times)
GDF
Re: Paper Space Objects
« Reply #15 on: March 28, 2018, 03:16:57 PM »
OOOOOH NICE
« Reply #16 on: March 28, 2018, 05:46:50 PM »
Thanks for assisting in my absence Ron :-)
Gary, my Set Attribute Values function may be more applicable (and efficient) for this task -
  1. (setq l
  2.     (list
  3.        '("SHTNO"  . "%<\\AcVar ctab>%")
  4.        '("DRHNO"  . "2113AL V1 R0")
  5.        '("PLANNO" . "2113AL Standard")
  6.         (cons "DATE"  (arch:c_date-issue (getvar "tdupdate")))
  7.         (cons "BPSNO" (substr (getvar "dwgprefix") 13 (- (strlen (getvar "dwgprefix")) 13)))
  8.     )
  9. )
  10. (if (setq s (ssget "_x" '((0 . "insert") (2 . "DRHortonTBA") (66 . 1) (410 . "~model"))))
  11.     (repeat (setq i (sslength s))
  12.         (LM:setattributevalues (ssname s (setq i (1- i))) l)
  13.     )
  14. )
« Reply #17 on: March 28, 2018, 08:12:12 PM »
Thanks for assisting in my absence Ron :)
Anytime Lee 😁
GDF
« Reply #18 on: March 29, 2018, 07:51:39 AM »
Thanks Lee
I love the use of fields for the sheet number...need to catch up here.
Gary
GDF
« Reply #19 on: March 29, 2018, 01:00:28 PM »
Need help with fields to update attribute
This field works:
This field does not work:
("DATE" . "%<\\AcVar date>%")
Or this:
("DATE" . "%<\\AcVar Date \f "MMMM d, yyyy">%")
« Reply #20 on: March 29, 2018, 01:05:27 PM »
Try:
("DATE" . "%<\\AcVar Date \\f \"MMMM d, yyyy\">%")
It is also sometimes necessary to use the UPDATEFIELD command or issue a REGEN for the field to display when populating attribute values.
« Reply #21 on: March 29, 2018, 01:08:29 PM »
This field works:
Or this:
You have to esc the \ and " like so: "%<\\AcVar Date \\f \"M/d/yyyy\">%"
DOH .. too slow :)
GDF
« Reply #22 on: March 29, 2018, 01:18:45 PM »
Forgot to mention, that I tried that also.
The field will not update with the current date.
GDF
« Reply #23 on: March 29, 2018, 01:24:05 PM »
Unless I double click on the tag to bring up the field dialog box...why?
« Reply #24 on: March 29, 2018, 01:29:00 PM »
Did you try UPDATEFIELD or REGEN?
GDF
« Reply #25 on: March 29, 2018, 01:32:12 PM »
No, only a regen
UPDATEFIELD is the way to go...and now I know and will start using fields.
Thanks guys
« Reply #26 on: March 29, 2018, 01:36:47 PM »
No, only a regen
Thanks guys
You're welcome Gary.
UPDATEFIELD only seems to be necessary for specific objects (attributes, multileader attributes), but isn't typically required when populating Text or MText with field expressions. Another point worth noting is when changing the field expression held by an object, it is sometimes necessary to clear the content first before populating the content with the new field expression (refer to the method used by my Quick Field program - line 205).
GDF
« Reply #27 on: March 29, 2018, 03:06:41 PM »
Will do..Thanks
Just playing around will learning fields:
(setq arch#sern (substr (getvar "dwgprefix") 13 (- (strlen (getvar "dwgprefix")) 13)))
(if (/= (ssget "x" '((0 . "insert")(2 . "sc-96"))) nil)(setq arch#scms "Scale = 1/8\" = 1'- 0\""))
(setq l
    (list
       '("DATE" . "%<\\AcVar Date \\f \"MMMM d, yyyy\">%")
       '("SCALE" . "%<\\AcVar.17.0 Lisp.arch#scms \\f \"%tc3\">%")
       '("BPSNO"  . "%<\\AcVar.17.0 Lisp.arch#sern \\f \"%tc3\">%")
[code/]
