I know I asked this awhile ago. It was more geared towards DOS.
https://www.theswamp.org/index.php?topic=46502.msg567302#msg567302But I stumbled on this Lisp routine and was wonder if it could do somewhat of the same?
https://www.theswamp.org/index.php?topic=30704.msg362918#msg362918What I am playing with is:
The user can select a folder.
Then User selects a Target Folder.
At the command prompt: User can add a Prefix to all the (dwgs) that are in the source folder. (i.e. VOID-....FileName.dwg)
Then the command would copy all the dwgs within the source folder. Copy them to the target folder and finally add the prefix to all the dwgs.
Is this something that can be done?
Thanks for the feedback guys!
