Author Topic: Add Xdata 1011 and OFFSET command  (Read 1764 times)
Lupo76
« on: April 05, 2016, 03:22:52 AM »
I have added a hd ata 1011 to certain objects.
When I copy one of these objects to another location, the copy contains same xdata, but with the coordinates update to reflect the new location of the copy.
But if I use the command OFFSET, coordinates xdata of the copy are not updated.
I'm wrong something or is a particular behavior as expected so I have to manage by code?
Marc'Antonio Alessi
  • Marco
Re: Add Xdata 1011 and OFFSET command
« Reply #1 on: April 05, 2016, 05:37:59 AM »
Yes, very strange... after Offset 1011 do not update (i.e. after Move), if the object is copied the 1011 is update but starting from wrong previous value...  :blink:
From help:
World Space Position
1011. Unlike a simple 3D point, the WCS coordinates are moved, scaled, rotated, and mirrored along with the parent entity to which the extended data belongs. The WCS position is also stretched when the STRETCH command is applied to the parent entity and when this point lies within the select window.
« Reply #2 on: April 05, 2016, 06:09:24 AM »
I believe there are known bugs pertaining to xdata group codes not updating following modification to objects, e.g.:
https://www.theswamp.org/index.php?topic=36249.0
https://forums.autodesk.com/t5/objectarx/xdata-1011-1012-amp-amp-1013-not-updating/td-p/4910994
Lupo76
« Reply #3 on: April 05, 2016, 08:57:56 AM »
Even BricsCAD V16 has the same behavior :-(
Then confirm that it is planned in this way? absurd!  :x
Marc'Antonio Alessi
  • Marco
« Reply #4 on: April 05, 2016, 10:51:57 AM »
Tested Copy, Mirror, Stretch, Move, Scale with a Line: all is OK (also in A2017).
Only Offset do not update 1011.  :wideeyed:
roy_043
  • BricsCAD 18
« Reply #5 on: April 05, 2016, 03:06:46 PM »
@ Lupo76 + Marc'Antonio Alessi:
Offsetting an entity can have varied results. Offsetting a circle will produce a new 'scaled' entity. Should the gc 1011 point be scaled in that case? Or should the position relative to the center (or the 'curve' start point) of the circle remain constant? And what is the most logical approach if offsetting a polyline results in multiple new entities? What behavior do you have in mind?
Marc'Antonio Alessi
  • Marco
« Reply #6 on: April 06, 2016, 04:23:30 PM »
I agree, then also I have done the same your reasoning that, probably, justify the not update of cg 1011.   :-)  :yes:
Lupo76
« Reply #7 on: April 08, 2016, 03:22:30 AM »
This is true! Actually had not thought about.
But actually I had solved the problem at the start redefining the OFFSET command, so that when the user selects an object of my application, it only works with linear objects with only 2 vertices ;-)
Quindi ora devo trovare un modo per implementare anche l'aggiornamento dell'xdata 1011 da codice :-(
PS. I put in check "Notify me of replies" in this post, but I do not receive any notification ... you tell me why?
roy_043
  • BricsCAD 18
« Reply #8 on: April 08, 2016, 04:44:18 AM »
It would be nice if you share your solution here:
https://www.theswamp.org/index.php?topic=51177.0
ChrisCarlson
« Reply #9 on: April 08, 2016, 08:25:37 AM »
Very curious how you wrote your own version of offset without using offset commands.
Marc'Antonio Alessi
  • Marco
« Reply #10 on: April 08, 2016, 09:33:13 AM »
I too have the same problem also in other posts!  :-(
Marc'Antonio Alessi
  • Marco
« Reply #11 on: April 08, 2016, 09:35:03 AM »
For a response post your code...
