I made a Lisp to export text in a drawing for a Google Earth KML file.
KML'm entering a point (marker) without figure.
Is correct?
(DEFUN TXTKML ()
(SETQ ARQKML (STRCAT (GETVAR "DWGPREFIX") (VL-FILENAME-BASE (GETVAR "DWGNAME")) ".KML"))
(SETQ ARQ (OPEN ARQKML "w"))
(WRITE-LINE "<?xml version=\"1.0\" encoding=\"UTF-8\"?>" ARQ)
(WRITE-LINE "<kml xmlns=\"http://www.opengis.net/kml/2.2\" xmlns:gx=\"http://www.google.com/kml/ext/2.2\" xmlns:kml=\"http://www.opengis.net/kml/2.2\" xmlns:atom=\"http://www.w3.org/2005/Atom\">" ARQ)
(WRITE-LINE "<Document>" ARQ)
(WRITE-LINE (STRCAT " <name>" (VL-FILENAME-BASE (GETVAR "DWGNAME")) ".kml</name>") ARQ)
(WRITE-LINE " <open>1</open>" ARQ)
(WRITE-LINE " <Style id=\"s_ylw-pushpin\">" ARQ)
(WRITE-LINE " <IconStyle>" ARQ)
(WRITE-LINE " <Icon>" ARQ)
(WRITE-LINE " </Icon>" ARQ)
(WRITE-LINE " </IconStyle>" ARQ)
(WRITE-LINE " <ListStyle>" ARQ)
(WRITE-LINE " </ListStyle>" ARQ)
(WRITE-LINE " </Style>" ARQ)
(SETQ ENT (CAR (ENTSEL "\nSELECT TEXT: ")))
(SETQ LIS (ENTGET ENT))
(SETQ TXT (CDR (ASSOC 1 LIS)))
(WRITE-LINE " <Placemark>" ARQ)
(WRITE-LINE (STRCAT " <name>" TXT "</name>") ARQ)
(WRITE-LINE " <styleUrl>#s_ylw-pushpin</styleUrl>" ARQ)
(WRITE-LINE " <Point>" ARQ)
(WRITE-LINE " <gx:drawOrder>1</gx:drawOrder>" ARQ)
(WRITE-LINE " <coordinates>-42.75294742841147,-22.72227626656398,0</coordinates>" ARQ) ;BE CALCULATED
(WRITE-LINE " </Point>" ARQ)
(WRITE-LINE " </Placemark>" ARQ)
(WRITE-LINE "</Document>" ARQ)
(WRITE-LINE "</kml>" ARQ)
(CLOSE ARQ)
(PRINC)
ok?
