Author Topic: redefine offset command  (Read 1859 times)
Lupo76
« on: April 01, 2016, 02:39:54 AM »
Hello to all,
I need to define the offset command, because I'd like to do some operations to results objects.
I wish the user could use all of the offset command options (Point / Delete / Multiple Layer ... ... etc.)
Unfortunately I have no idea how to do.
(defun c:newoffset ()
   (command "_.offset" pause pause pause ??????)
   (setq newogg (??????)
  [code that will handle the selection set 'newogg']
Can you help me?
roy_043
  • BricsCAD 18
Re: redefine offset command
« Reply #1 on: April 01, 2016, 07:07:45 AM »
Here is a solution:
  1. (defun c:NewOffset ( / doc enm ss tmp)
  2.   (if
  3.     (or
  4.       (setq enm (entlast))
  5.       (progn
  6.         (princ "\nNo entity available for offset ")
  7.         nil
  8.       )
  9.     )
  10.     (progn
  11.       (if (= 8 (logand (getvar 'undoctl) 8))
  12.         (vla-endundomark doc)
  13.       )
  14.       (vla-startundomark doc)
  15.       (while (setq tmp (entnext enm))
  16.         (setq enm tmp)
  17.       )
  18.       (command "_.offset")
  19.       (while (/= 0 (logand (getvar 'cmdactive) 3))
  20.         (command pause)
  21.       )
  22.       (setq ss (ssadd))
  23.       (while (setq enm (entnext enm))
  24.         (ssadd enm ss)
  25.       )
  26.       (if (/= 0 (sslength ss))
  27.         (sssetfirst nil ss)
  28.       )
  29.       (vla-endundomark doc)
  30.     )
  31.   )
  32.   (princ)
  33. )
« Last Edit: April 01, 2016, 07:12:02 AM by roy_043 »
Lupo76
« Reply #2 on: April 03, 2016, 11:41:16 AM »
Here is a solution:
  2.   (if
  3.     (or
  5.       (progn
  7.         nil
  8.       )
  9.     )
  10.     (progn
  13.       )
  16.         (setq enm tmp)
  17.       )
  20.         (command pause)
  21.       )
  24.         (ssadd enm ss)
  25.       )
  28.       )
  30.     )
  31.   )
  32.   (princ)
  33. )
Hello Roy,
thanks for your code!
It works very well but it has a small problem in AutoCAD, it does not display the preview of the result :oops:
Can you also solve this?  :roll:
Lupo76
« Reply #3 on: April 03, 2016, 12:11:29 PM »
I realized just now of a more serious problem.
With your code I can control the user-selected object only after the command has been completed.
In my first post I explained the problem badly.
I have to check that each user-selected object is confirmed to my needs.
A practical example is the OFFSET command that always works, except when the user selects an object LINE.
can you do this?
roy_043
  • BricsCAD 18
« Reply #4 on: April 04, 2016, 03:50:08 AM »
In BricsCAD V16 there is a preview. I don't know why AutoCAD behaves in this manner or how to solve it.
roy_043
  • BricsCAD 18
« Reply #5 on: April 04, 2016, 03:55:32 AM »
can you do this?
If you want to validate the source entities, something like the code below will work. But it does not expose all options of the OFFSET command.
  1. (defun c:NewOffset2 ( / N_GetEntity N_GetDistance dist doc enm enmOffset pt ss tmp)
  2.
  3.   (defun N_GetEntity ( / enm)
  4.     (if
  5.       (and
  6.         (setq enm (car (entsel "\nSelect entity: ")))
  7.         (vl-position
  8.           (vla-get-objectname (vlax-ename->vla-object enm))
  9.           '("AcDb2dPolyline" "AcDbArc" "AcDbCircle" "AcDbEllipse" "AcDbLine" "AcDbPolyline" "AcDbSpline")
  10.         )
  11.       )
  12.       enm
  13.     )
  14.   )
  15.
  16.   (defun N_GetDistance ( / dist)
  17.     (initget 6)
  18.     (setq dist
  19.       (getdist
  20.         (if (< 0 (getvar 'offsetdist))
  21.           (strcat "\nOffset distance <" (rtos (getvar 'offsetdist)) ">: ")
  22.           "\nOffset distance: "
  23.         )
  24.       )
  25.     )
  26.     (cond
  27.       (dist
  28.         (setvar 'offsetdist dist)
  29.         dist
  30.       )
  31.       ((< 0 (getvar 'offsetdist))
  32.         (getvar 'offsetdist)
  33.       )
  34.     )
  35.   )
  36.
  37.   (if
  38.     (or
  39.       (setq enm (entlast))
  40.       (progn
  41.         (princ "\nNo entity available for offset ")
  42.         nil
  43.       )
  44.     )
  45.     (progn
  46.       (if (= 8 (logand (getvar 'undoctl) 8))
  47.         (vla-endundomark doc)
  48.       )
  49.       (vla-startundomark doc)
  50.       (while (setq tmp (entnext enm))
  51.         (setq enm tmp)
  52.       )
  53.       (if (setq dist (N_GetDistance))
  54.         (while
  55.           (and
  56.             (setq enmOffset (N_GetEntity))
  57.             (setq pt (getpoint "\nSide for parallel copy: "))
  58.           )
  59.           (setvar 'cmdecho 0)
  60.           (command "_.offset" dist enmOffset pt "")
  61.           (setvar 'cmdecho 1)
  62.         )
  63.       )
  64.       (setq ss (ssadd))
  65.       (while (setq enm (entnext enm))
  66.         (ssadd enm ss)
  67.       )
  68.       (if (/= 0 (sslength ss))
  69.         (sssetfirst nil ss)
  70.       )
  71.       (vla-endundomark doc)
  72.     )
  73.   )
  74.   (princ)
  75. )
ChrisCarlson
« Reply #6 on: April 04, 2016, 08:05:45 AM »
What additional functions do you want?
Lupo76
« Reply #7 on: April 04, 2016, 01:45:41 PM »
The problem is just that!
I would like to validate the source objects and keep all the OFFSET command options  :cry:
