Hello to all,
I need to define the offset command, because I'd like to do some operations to results objects.
I wish the user could use all of the offset command options (Point / Delete / Multiple Layer ... ... etc.)
Unfortunately I have no idea how to do.
(defun c:newoffset ()
(command "_.offset" pause pause pause ??????)
(setq newogg (??????)
[code that will handle the selection set 'newogg']
Can you help me?
