Author Topic: group code of spline  (Read 1331 times)
sysuwzx
  • Mosquito
« on: March 31, 2016, 08:42:50 AM »
When i select a spline, the property named "Knot parameterization" on the properties panel can be changed to "chord" "sqrtchord" "uniform" and "custom".
My question is, is there one group code control this property? If yes, what is it? cant find it in the dxf reference
roy_043
  • BricsCAD 18
Re: group code of spline
« Reply #1 on: March 31, 2016, 09:08:16 AM »
It seems to be undocumented, I think it is gc 70.
Stefan
« Reply #2 on: March 31, 2016, 05:26:04 PM »
Roy is right, 70 is the code that holds the knot parameterization.
From dxf reference
Group code 70: Spline flag (bit coded):
1 = Closed spline
2 = Periodic spline
4 = Rational spline
8 = Planar
16 = Linear (planar bit is also set)
It seems incomplete, but is easy to find the other valid values:
32 = chord
64 = sqrt. chord
128 = uniform
256 = custom
512 = show CV frame
1024 = if present, the spline is defined by fit points. Otherwise, by control vertices.
sysuwzx
  • Mosquito
« Reply #3 on: March 31, 2016, 08:10:15 PM »
What you guess is right! And the document is not complete. Thanks a lot!
sysuwzx
  • Mosquito
« Reply #4 on: March 31, 2016, 08:10:54 PM »
From dxf reference
1 = Closed spline
2 = Periodic spline
4 = Rational spline
8 = Planar
32 = chord
64 = sqrt. chord
128 = uniform
256 = custom
512 = show CV frame
Wonderful! Thanks! :smitten:
