From help:
vports (AutoLISP)
Returns a list of viewport descriptors for the current viewport configuration
(vports)
Return Values
One or more viewport descriptor lists consisting of the viewport identification number and the coordinates of the viewport's lower-left and upper-right corners.
If the AutoCAD TILEMODE system variable is set to 1 (on), the returned list describes the viewport configuration created with the AutoCAD VPORTS command. The corners of the viewports are expressed in values between 0.0 and 1.0, with (0.0, 0.0) representing the lower-left corner of the display screen's graphics area, and (1.0, 1.0) the upper-right corner. If TILEMODE is 0 (off), the returned list describes the viewport objects created with the MVIEWcommand. The viewport object corners are expressed in paper space coordinates.
Viewport number 1 is always paper space when TILEMODE is off. Examples
Given a single-viewport configuration with TILEMODE on, the vports function might return the following:
((1 (0.0 0.0) (1.0 1.0)))
So, Paper Space itself is a special kind of VIEWPORT.
