Hi Roy
I just couldn't work out the syntax for using command and the only example I could find was send command.
Hi ChrisCarlson and mjfarrell
Thanks for the responses.
As regards dynamic block, you are probably right but I was just trying to reproduce what I was doing manually and was just interested in trying to resolve why the array wasn't associative.
I am really just trying to draw a coordinate grid so I only draw it once in the job so there is no advantage in either method really.
Thanks again for your suggestions.
Scott
