First thing that comes to mind is:
You could have a situation where you want the user to "Name" the selection set or several of selection sets with user names.
Obviously you could have a loop to getsting the names. Also the "Select Objects:" prompt is avoided.
True, -
I used it to override the "Select Objects" prompt - which probably isn't using it to its full extent, but it was fun to make.
I can see other uses for it though - for instance, ssget doesnt allow for keywords, or any string input (except for the usual "Last/Window.."), also, I had considered using it so that I could prompt a user to either select a selection set of blocks, or specify a block name.
Lee there is no way to remove [Shift + Click] items from the SS.
Good point - but I wanted to avoid the necessity of Expess Tools, as I can't see any other way of detecting a down-shift in LISP without using the acet-sys-shift-down function
But, if you can see a way around this just shout
Lee
