Code Red => AutoLISP (Vanilla / Visual) => Topic started by: Lupo76 on April 05, 2016, 03:22:52 AM
I have added a hd ata 1011 to certain objects.
When I copy one of these objects to another location, the copy contains same xdata, but with the coordinates update to reflect the new location of the copy.
But if I use the command OFFSET, coordinates xdata of the copy are not updated.
I'm wrong something or is a particular behavior as expected so I have to manage by code?
Yes, very strange... after Offset 1011 do not update (i.e. after Move), if the object is copied the 1011 is update but starting from wrong previous value... :blink:
From help:
World Space Position
1011. Unlike a simple 3D point, the WCS coordinates are moved, scaled, rotated, and mirrored along with the parent entity to which the extended data belongs. The WCS position is also stretched when the STRETCH command is applied to the parent entity and when this point lies within the select window.
I believe there are known bugs pertaining to xdata group codes not updating following modification to objects, e.g.:
https://www.theswamp.org/index.php?topic=36249.0
https://forums.autodesk.com/t5/objectarx/xdata-1011-1012-amp-amp-1013-not-updating/td-p/4910994
Even BricsCAD V16 has the same behavior :-(
Then confirm that it is planned in this way? absurd! :x
Tested Copy, Mirror, Stretch, Move, Scale with a Line: all is OK (also in A2017).
Only Offset do not update 1011. :wideeyed:
@ Lupo76 + Marc'Antonio Alessi:
Offsetting an entity can have varied results. Offsetting a circle will produce a new 'scaled' entity. Should the gc 1011 point be scaled in that case? Or should the position relative to the center (or the 'curve' start point) of the circle remain constant? And what is the most logical approach if offsetting a polyline results in multiple new entities? What behavior do you have in mind?
I agree, then also I have done the same your reasoning that, probably, justify the not update of cg 1011. :-) :yes:
This is true! Actually had not thought about.
But actually I had solved the problem at the start redefining the OFFSET command, so that when the user selects an object of my application, it only works with linear objects with only 2 vertices ;-)
Quindi ora devo trovare un modo per implementare anche l'aggiornamento dell'xdata 1011 da codice :-(
PS. I put in check "Notify me of replies" in this post, but I do not receive any notification ... you tell me why?
It would be nice if you share your solution here:
https://www.theswamp.org/index.php?topic=51177.0
Very curious how you wrote your own version of offset without using offset commands.
I too have the same problem also in other posts! :-(
For a response post your code...
