Author Topic: Jigging with attributes  (Read 2472 times)
Bennos
  • Mosquito
« on: May 14, 2007, 10:09:53 PM »
Hello All,
What i'm trying to do is insert a block with attributes, using the entity jig.
I can add a new block reference into the jig but the attributes don't come through (seen on with the entity jig). I gathered that they need to be appended from the blocktablerecord after you added the blockreference into the database.
What i was hoping to do was, insert the block into the database first and then use the entity jig to move, roatate and scale the block reference. Would this be the correct way of doing this (end result would be to see the attributes whilst jigging), or is there another way to append attributes into the jig prior to adding to the database?
Any thoughts/theories would be great.
Bennos
Roland Feletic
Re: Jigging with attributes
« Reply #1 on: May 15, 2007, 01:53:56 AM »
That is a good question, i had the same problem here. I'm really interested if it is possible to do this.
sinc
« Reply #2 on: May 15, 2007, 07:46:31 AM »
I know about "gettin jiggy wit it", but what's an "entity jig"?
