Author Topic: AutoCAD LispWiki  (Read 5611 times)
Krushert
  • FREE BEER Tomorrow!!
Re: AutoCAD LispWiki
« Reply #1 on: April 23, 2008, 07:01:25 AM »
Darn late again. I was just coming to post that.  :-)
(I think would be late for my own funeral)
The site looks promising and I like how it organized.
jonesy
  • SuperMod
« Reply #2 on: April 23, 2008, 07:34:06 AM »
Great link Kerry...
Bookmarked for future use
POCKETS
« Reply #3 on: April 23, 2008, 08:10:47 AM »
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #4 on: April 23, 2008, 08:43:54 AM »
  • Custom Title
« Reply #5 on: April 23, 2008, 08:59:28 AM »
There is no page titled "theswamp".
CADaver
« Reply #6 on: April 23, 2008, 09:49:31 AM »
That needs to be fixed!!!
deegeecees
« Reply #7 on: April 23, 2008, 09:58:18 AM »
Woohoo!
« Reply #8 on: April 23, 2008, 10:23:28 AM »
All code there is released under the "GNU Free Documentation License".
IMO it should be a "BSD" style.
Chuck Gabriel
« Reply #9 on: April 23, 2008, 11:48:34 AM »
Anybody can edit those pages.  You just have to create an account.
See -> http://lispwiki.com/index.php5?title=AutoLISP_Resources
  • Custom Title
« Reply #10 on: April 23, 2008, 12:13:30 PM »
Thanks Chuck! :)
qjchen
  • Best wishes to all
« Reply #11 on: April 23, 2008, 07:18:17 PM »
Excellent site, thanks for sharing:)
http://qjchen.mjtd.com
My blog http://chenqj.blogspot.com (Chinese, can be translate into English)
qjchen
« Reply #12 on: April 25, 2008, 01:15:02 AM »
I add it here:)
http://lispwiki.com/index.php5?title=AutoLISP_Links
and I have ever collected a lot of Lisp website here (many of them are in Chinese)
http://chenqj.blogspot.com/2006/09/lisp.html
I will add some to LispWiki also.
« Last Edit: April 25, 2008, 09:56:01 AM by yuanqiu »
« Reply #13 on: April 25, 2008, 08:45:31 AM »
Good Job yuanqiu 8-)
« Reply #14 on: April 30, 2008, 10:14:04 AM »
This is an outstanding gesture and effort, but i still have a problem with the License.
Besides the fact that all that code is released under a  ``Documentation License'' (like books and manuals) instead of a regular GNU type of license...[you] do realize that [you] can not use any of that code in a ``for sale -- no source'' type of condition right? Not to mention any derivative of any of that code must then be released under the exact same license.
For example I will take a very simple procedure found on that site.
Found here:
[ http://lispwiki.com/index.php5?title=Color_to_Bylayer ]
Orig:
(apply '(lambda ()
         (defun *error* (msg)
          (prin1 msg))
         (setq uecho (getvar "cmdecho"))
         (setvar "cmdecho" 0)
         (prompt "\nSelect Items To Change To BYLAYER :")
         ;(setq ps1 (ssadd))
         (setq ps1 (ssget))
         (command "CHANGE" ps1 "" "P" "C" "BYLAYER" "LT" "BYLAYER" "")
         (setvar "cmdecho" uecho)
Now lets clean up that code a bit for our imediate needs.
My Derivative:
( (lambda ( / *error* uecho ps1)
 ;; `apply' not necessary
 ;; localize vars
   (if (eq (logand (getvar "CMDACTIVE")) 1)
 ;; lets cancel any command still running...just in case!?
      (repeat 2 (command)) )
   (prin1 msg))
  (setq ps1 (ssget))
   (if ps1
  ;; lets add a bit of error checking (crude but effective)
       (command "CHANGE" ps1 "" "P" "C" "BYLAYER" "LT" "BYLAYER" ""))
  (princ)) )
Now the orig was relased under the GNU doc licence, and so is mine. Not because I want it to be (i didnt want to give this code to my client who just paid $500 for this gem) but I have to.
Make your own and release it under the BSD License.
